Python Help
Go to solution Solved by Linus_torvalds,
Do you know how I would implement that in this case???
here it works :)
def border_msg(msg):    split_msg = None    longest = 0    border = None    message = None    mylist = []        split_msg = msg.split('\n')        for i in split_msg:    	mylist.append(i)        longest = len(max(mylist, key=len))        border = '+%s+\n' %('-'*(longest + 2))    message = border        for i in split_msg:        message += '| %s |\n' % i.center(longest, ' ')        message += border        return message    print(border_msg('hello there\nmy name is nick'))
Hey guys I have to write a program that when given a string does this:
+-­‐-­‐-­‐-­‐-­‐-­‐-­‐+|    hello     |+-­‐-­‐-­‐-­‐-­‐-­‐-­‐+
this is my code so far:
def border_msg(msg):    split_msg = None    longest = 0    border = None    message = None        split_msg = msg.split('\n')        for i in split_msg:        if len(i) > longest:            longest = len(i)        border = '+%s+\n' %('-'*(longest + 2))    message = border        for i in split_msg:        message += '| %s |\n' % i        message += border        return message    print(border_msg('hello there\nmy name is nick'))
But my code does this:
+-----------------+| hello there || my name is nick |+-----------------+
How can I center that first line of text? Thanks so much for your help!
https://linustechtips.com/topic/465679-python-help/
here it works :)
Computer users fall into two groups:
those that do backups
those that have never had a hard drive fail.
https://linustechtips.com/topic/465679-python-help/#findComment-6268783
here it works :)
Thanks!!! I unfortunately handed in the assignment already but thanks!
https://linustechtips.com/topic/465679-python-help/#findComment-6283826
