I've been running 61c while gaming and 65c tops while stress testing for a month. 4690k at 4.6GHz and 1.220v using a H105 cooler. Friday I tried out the Battlefront Beta, I noticed I had crossed into the low 70s CPU temp while playing it. Since then I had my gaming temp be in the mid 60s and stress testing goes into the low 70s at times. Even Cinebench that was always at 61c is now in the mid 60s. Yesterday I tried changing the thermal paste just in case it was the stock paste that came with the H105, at first it helped and temps were normal but today they're back to the elevated numbers. I did also flip my PSU on Friday because the fan never comes so there's no benefit to having the fan open to the case.
It's driving me crazy. performance numbers are exactly the same, I even got my best Cinebench ever yesterday.
If anyone asks you never saw me.
https://linustechtips.com/topic/465475-temp-issue-with-4690k/
That isn't that bad ...
CPUIntel 4670k  Motherboard - Gigabyte GA-Z87X-D3H  RAMKingston HyperX 8GB  GPU - EVGA 780  Case - Fractal Design Define R4    Storage - 2TB WD Black, Samsung 840 Evo 128GB     PSU - Corsair RM650  Display -  Benq XL2430T and Acer S235HL  Cooling - CM Hyper 212 Evo  Keyboard - Corsair K95  Mouse - Razer Deathadder  Sound - Sennheiser HD 558                                 Mic - Blue Snowball  Phone- OnePlus One  Tablet - Nvidia Shield
https://linustechtips.com/topic/465475-temp-issue-with-4690k/#findComment-6246295
those temperatures are fine.... i don't see why you're worrying.
the change in temperature isn't that big of a deal, its fine. the only i'd be worried if it goes over 90c.
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/465475-temp-issue-with-4690k/#findComment-6246316
it's not the temp really, but the change in temp.
It's not a huge change, it should be fine
https://linustechtips.com/topic/465475-temp-issue-with-4690k/#findComment-6246328
dude lol. 70 degrees is really good. stop worrying about 5 degrees unless its over 80
CPU: Intel i7 8700k || Motherboard: Asus Z370-E ROG || RAMCorsair 4266 2x8gb || GPU: Sapphire r9 280x tri-x || Case: Corsair 780t ||
Storage: Samsung 850 Evo 250GB, 1TB Segate Barracuda HDD || PSUSeasonic M12II Evo 850w || Display: AOC i2367FH 1920x1080p 23 Inch ||
CPU Cooler: Corsair h80 || KeyboardCorsair Strafe || MouseCorsair Scimitar || HeadsetHyper X Cloud II || OS: Windows 10 ||
https://linustechtips.com/topic/465475-temp-issue-with-4690k/#findComment-6246491
I know it's an acceptable temp, what I'm trying to solve is why did it change? Nothing has changed except flipping the PSU and playing the Battlefront beta. If one of them caused an issue I'd rather solve it while isn't a non issue than wait until I have out of control temps. I'd just flip the PSU but it's a major pain and it allowed for another intake fan in the bottom to be installed. My GPU temps are down.
First thing I did was unplug the new fan, gpu temp went up and the CPU stayed the same.
https://linustechtips.com/topic/465475-temp-issue-with-4690k/#findComment-6246525
A small change like that can be caused by a number of factors. Your thermal paste might have dried a bit for example. The pump in your aio might be wearing out. Dust in the radiator, your motherboard sending a bit more voltage to the cpu, the cpu itself might be the problem with the paste under the heat spreader being uneven, inconsistent, or just the cpu degrading.
The why of it is pretty much impossible to nail down on an online forum. The only way to know where the problem is, is by removing variables
My rig:
CPU: i5 4690k 24/7 @4.4ghz (1.165v) Max 4.7ghz (1.325v) COOLER: NZXT Kraken X61 MOBO: Asus Z97-A   RAM: 16GB Crucial Ballistix Tactical   GPU: EVGA GTX 970 SSC   PSU: EVGA GS 650W   CASE: NZXT Phantom 530 HDD: WD Caviar Blue 1TB + WD Black 2TB
https://linustechtips.com/topic/465475-temp-issue-with-4690k/#findComment-6246595
That's what I was looking for.
I applied new paste but I might re-apply to see if I didn't use enough. (was scared to use to much and cause a problem. used the X method)
Pump is a month old but I will try try blowing out the radiator.
I'll be really pissed if I ruined my CPU by playing the stupid beta. Did a search and I'm not alone, I immediately uninstalled anything related to the beta and ran another test. Still higher than normal.
https://linustechtips.com/topic/465475-temp-issue-with-4690k/#findComment-6246630
The beta wouldn't have ruined your cpu lol.
I hope you find the issue, I just don't see how a game could ruin your cpu
My rig:
https://linustechtips.com/topic/465475-temp-issue-with-4690k/#findComment-6246643
I don't see how it could be possible but I've gone through everything. Going to try a new application of thermal paste in hope I didn't do it right. Thanks for the help
https://linustechtips.com/topic/465475-temp-issue-with-4690k/#findComment-6246737
My custom loop jumps temperatures up a bit every month or so. Usually it's just dust clogged filters and dust between the fans and rad.
A good shot from the compressor brings everything back into line. Check your rad, that's the most likely culprit in my experience.
The New Machine: Intel 11700K / Strix Z590-A WIFI II / Patriot Viper Steel 4400MHz 2x8GB / Gigabyte RTX 3080 Gaming OC w/ Bykski WB / x4 1TB SSDs (x2 M.2, x2 2.5) / Corsair 5000D Airflow White / EVGA G6 1000W / Custom Loop CPU & GPU
The Rainbow X58: i7 975 Extreme Edition @4.2GHz, Asus Sabertooth X58, 6x2GB Mushkin Redline DDR3-1600 @2000MHz, SP 256GB Gen3 M.2 w/ Sabrent M.2 to PCI-E, Inno3D GTX 580 x2 SLI w/ Heatkiller waterblocks, Custom loop in NZXT Phantom White, Corsair XR7 360 rad hanging off the rear end, 360 slim rad up top. RGB everywhere.
https://linustechtips.com/topic/465475-temp-issue-with-4690k/#findComment-6246847
Radiator was clean but I blew it out anyway. I probably used too much thermal past, re applied using less paste and the line method. (little more than a grain of rice) Still getting higher temperatures. Tried adjusting my voltage and REALLY pissed off Intel XTU again, lost a bio and removed all utilities for the CPU. Re installed RealTempGT.
Still getting higher temps than were normal. My system monitoring software from Gigabyte the maker of the motherboard shows normal temps for the CPU. I tried to test the sensors for RealtempGT but it tries to use a file I don't have. Still stumped.
https://linustechtips.com/topic/465475-temp-issue-with-4690k/#findComment-6247464
Tried flipping the PSU were it was, nothing. Temps have gone up again and I'm now running at 70c while gaming which is 10 degrees up from before. I even went back to stock clock and the temperature is still elevated. Going to try and do a push/pull on the radiator, only thing I can think of to try.
https://linustechtips.com/topic/465475-temp-issue-with-4690k/#findComment-6249190
Sorry to bump this but I really need some help.
I have it narrowed down to airflow in the case. I was testing a push pull set-up with the case side cover off and BAM! right back to normal. I was smart and tried taking the extra fan off first (having the fan outside the case would have involved drilling) and tested with just the side cover off no other changes, still normal temps. Installed the side cover and I'm back to the elevated temp on the CPU. Nothing has changed as far as my case goes. I did have the PSU flipped but I have that back in it's original fan up position.
What could cause airflow in my case to change when nothing about the case has changed?
EDIT# All filters are clean.
https://linustechtips.com/topic/465475-temp-issue-with-4690k/#findComment-6252025
My FX-8370 with 212 Evo is around 49c to 54c mostly... :o (yours is a bit high, could be your case?)
Zen-III-X8-5900X (Gamestation 5)
Case: Medion Micro-ATX Case / Case Fan Front: SUNON MagLev PF70251VX-Q000-S99 70mm / Case Fan Rear: Fanner Tech(Shen Zhen)Co.,LTD. 80mm (Purple) / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: AMD Near-silent 125w Thermal Solution / CPU: AMD Ryzen 5 3600, 6-cores, 12-threads, 4.2/4.2GHz, 35,3MB cache (T.S.M.C. 7nm FinFET) / CPU: AMD Ryzen 9 5900X, 12(8)-cores, 24(16)-threads, 4.5/4.8GHz, 70.5MB(68,35MB) cache (T.S.M.C. 7nm FinFET) / Display: HP 24" L2445w (64Hz OC) 1920x1200 / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / GPU: ASUS Radeon RX 6600 XT DUAL OC RDNA2 32CUs @2.6GHz 10.6 TFLOPS (T.S.M.C. 7nm FinFET) R.ID (NimeZ drivers) / Keyboard: HP KB-0316 PS/2 (Nordic) / Motherboard: ASRock B450M Pro4, Socket-AM4 (SAM enabled) / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 550W / RAM A1 & B1: G.SKILL DDR4-3600MHz CL18-20-21-39-60-1T "Samsung 8Gbit C-Die" (2x8GB) / RAM A2 & B2: HyperX DDR4-3600MHz CL16-18-19-37-85-1T "SK Hynix 8Gbit CJR" (2x16GB) / Operating System: Windows 10 Home / Sound 1: Zombee Z500 / Sound 2: Logitech Stereo Speakers S-150 / Storage 1 & 2: Samsung 850 EVO 500GB SSD / Storage 3: Western Digital My Passport 2.5" 2TB HDD / Storage 4: Western Digital Elements Desktop 2TB HDD / Storage 5: Kingston A2000 1TB M.2 NVME SSD / Wi-fi & Bluetooth: ASUS PCE-AC55BT Wireless Adapter (Intel)
 Lake-V-X6-10600 (Gaming PC)
R23 score MC: 9190pts | R23 score SC: 1302pts
R20 score MC: 3529cb | R20 score SC: 506cb
Case: Cooler Master HAF XB Evo Black / Case Fan(s) Front: Noctua NF-A14 ULN 140mm Premium Fans / Case Fan(s) Rear: Corsair Air Series AF120 Quiet Edition (red) / Case Fan(s) Side: Noctua NF-A6x25 FLX 60mm Premium Fan / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: Cooler Master Hyper 212 Evo / CPU: Intel Core i5-10600(ASUS Performance Enhancement), 6-cores, 12-threads, 4.4/4.8GHz, 13,7MB cache (Intel 14nm++ FinFET) / Display: ASUS 24" LED VN247H (67Hz OC) 1920x1080p / GPU: Gigabyte Radeon RX Vega 56 Gaming OC GCN5 56CUs @1.7GHz 12.19 TFLOPS (Samsung 14nm FinFET) R.ID (NimeZ drivers) / Keyboard: Logitech Desktop K120 (Nordic) / Motherboard: ASUS PRIME B460 PLUS, Socket-LGA1200 (SAM enabled) / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 850W / RAM A1 & B1: HyperX DDR4-2666MHz CL13-15-15-30-45-2T "Samsung 8Gbit C-Die" (2x8GB) / RAM A2 & B2: Juhor DDR4-3200MHz CL16-20-20-38-72-2T "SK Hynix 8Gbit MFR" (2x16GB) / Operating System: Windows 10 Home / Sound: Zombee Z300 / Storage 1 & 2: Samsung 850 EVO 500GB SSD / Storage 3: Seagate® Barracuda 2TB HDD / Storage 4: Seagate® Desktop 2TB SSHD / Storage 5: Crucial P1 1000GB M.2 SSD/ Storage 6: Western Digital WD7500BPKX 2.5" HDD / Wi-fi: TP-Link TL-WN851N 11n Wireless Adapter (Qualcomm Atheros)
Vishera-X8-9370 | R20 score MC: 1476cb
Case: Cooler Master HAF XB Evo Black / Case Fan(s) Front: Noctua NF-A14 ULN 140mm Premium Fans / Case Fan(s) Rear: Corsair Air Series AF120 Quiet Edition (red) / Case Fan(s) Side: Noctua NF-A6x25 FLX 60mm Premium Fan / Case Fan VRM: SUNON MagLev KDE1209PTV3 92mm / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: Cooler Master Hyper 212 Evo / CPU: AMD FX-8370 (Base: @4.4GHz | Turbo: @4.7GHz) Black Edition Eight-Core (Global Foundries 32nm) / Display: ASUS 24" LED VN247H (67Hz OC) 1920x1080p / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / GPU: Gigabyte Radeon RX Vega 56 Gaming OC @1501MHz (Samsung 14nm FinFET) / Keyboard: Logitech Desktop K120 (Nordic) / Motherboard: MSI 970 GAMING, Socket-AM3+ / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 850W PSU / RAM 1, 2, 3 & 4: Corsair Vengeance DDR3-1866MHz CL8-10-10-28-37-2T (4x4GB) 16.38GB / Operating System 1: Windows 10 Home / Sound: Zombee Z300 / Storage 1: Samsung 850 EVO 500GB SSD (x2) / Storage 2: Seagate® Barracuda 2TB HDD / Storage 3: Seagate® Desktop 2TB SSHD / Wi-fi: TP-Link TL-WN951N 11n Wireless Adapter
Godavari-X4-880K | R20 score MC: 810cb
Case: Medion Micro-ATX Case / Case Fan Front: SUNON MagLev PF70251VX-Q000-S99 70mm / Case Fan Rear: Fanner Tech(Shen Zhen)Co.,LTD. 80mm (Purple) / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: AMD Near-silent 95w Thermal Solution / Cooler: AMD Near-silent 125w Thermal Solution / CPU: AMD Athlon X4 860K Black Edition Elite Quad-Core (T.S.M.C. 28nm) / CPU: AMD Athlon X4 880K Black Edition Elite Quad-Core (T.S.M.C. 28nm) / Display: HP 19" Flat Panel L1940 (75Hz) 1280x1024 / GPU: EVGA GeForce GTX 960 SuperSC 2GB (T.S.M.C. 28nm) / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / Keyboard: HP KB-0316 PS/2 (Nordic) / Motherboard: MSI A78M-E45 V2, Socket-FM2+ / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 550W PSU / RAM 1, 2, 3 & 4: SK hynix DDR3-1866MHz CL9-10-11-27-40 (4x4GB) 16.38GB / Operating System 1: Ubuntu Gnome 16.04 LTS (Xenial Xerus) / Operating System 2: Windows 10 Home / Sound 1: Zombee Z500 / Sound 2: Logitech Stereo Speakers S-150 / Storage 1: Samsung 850 EVO 500GB SSD (x2) / Storage 2: Western Digital My Passport 2.5" 2TB HDD / Storage 3: Western Digital Elements Desktop 2TB HDD / Wi-fi: TP-Link TL-WN851N 11n Wireless Adapter
Acer Aspire 7738G custom (changed CPU, GPU & Storage)
CPU: Intel Core 2 Duo P8600, 2-cores, 2-threads, 2.4GHz, 3MB cache (Intel 45nm) / GPU: ATi Radeon HD 4570 515MB DDR2 (T.S.M.C. 55nm) / RAM: DDR2-1066MHz CL7-7-7-20-1T (2x2GB) / Operating System: Windows 10 Home / Storage: Crucial BX500 480GB 3D NAND SATA 2.5" SSD
Complete portable device SoC history:
Apple A4 - Apple iPod touch (4th generation)
Apple A5 - Apple iPod touch (5th generation)
Apple A9 - Apple iPhone 6s Plus
HiSilicon Kirin 810 (T.S.M.C. 7nm) - Huawei P40 Lite / Huawei nova 7i
Mediatek Dimensity 700 (T.S.M.C 7nm) - Cherry Mobile Aqua S10 Pro 5G
Mediatek MT2601 (T.S.M.C 28nm) - TicWatch E
Mediatek MT6580 (T.S.M.C 28nm) - TECNO Spark 2 (1GB RAM)
Mediatek MT6592M (T.S.M.C 28nm) - my|phone my32 (orange)
Mediatek MT6592M (T.S.M.C 28nm) - my|phone my32 (yellow)
Mediatek MT6735 (T.S.M.C 28nm) - HMD Nokia 3 Dual SIM
Mediatek MT6737 (T.S.M.C 28nm) - Cherry Mobile Flare S6
Mediatek MT6739 (T.S.M.C 28nm) - my|phone myX8 (blue)
Mediatek MT6739 (T.S.M.C 28nm) - my|phone myX8 (gold)
Mediatek MT6750 (T.S.M.C 28nm) - honor 6C Pro / honor V9 Play
Mediatek MT6765 (T.S.M.C 12nm) - TECNO Pouvoir 3 Plus
Mediatek MT6797D (T.S.M.C 20nm) - my|phone Brown Tab 1
Qualcomm MSM8926 (T.S.M.C. 28nm) - Microsoft Lumia 640 LTE
Qualcomm MSM8974AA (T.S.M.C. 28nm) - Blackberry Passport
Qualcomm SDM710 (Samsung 10nm) - Oppo Realme 3 Pro
https://linustechtips.com/topic/465475-temp-issue-with-4690k/#findComment-6252132
It's something with the airflow in the case. I just can't figure out what. I even tried lowering the fan speed of the GPU. None of the fans have changed speed and they're all working. Nothing is blocking anything on the case. It's driving me mental. Going to try increasing fan speed with the case fans, I've never had to but it's worth a shot.
https://linustechtips.com/topic/465475-temp-issue-with-4690k/#findComment-6252168
I just got a huge box shaped case to avoid any errrrm issues like this... :P
https://linustechtips.com/topic/465475-temp-issue-with-4690k/#findComment-6252176
I have a C70 LOL, it's as big a mid case as you can get. Tried manually setting the fans on full speed using the fan controller and my temp went up! This is crazy. I already tested my sensors so it's not that.
https://linustechtips.com/topic/465475-temp-issue-with-4690k/#findComment-6252229
Weird try to see if there is any dust near the CPU? :D
https://linustechtips.com/topic/465475-temp-issue-with-4690k/#findComment-6252263
maybe because you are using the x method
my noctua nh d15 recommend me to put a little on the center
and my temp while stress test don't go above 57C
I'm MARIA 23 years old Girl (Female) .
Christmas is all about hope , and that hope is NOT possible without JESUS king of kings . I love Christmas .
https://linustechtips.com/topic/465475-temp-issue-with-4690k/#findComment-6252283
Just had the cooler off yesterday, the CPU is as clean as it can get. I used the line method and made sure to not use too much.
I am officially mental. Now having the case cover off doesn't help. I think it's getting hot over time and that's why having the cover off made a difference. Letting it sit on a load through CPU-Z to see if the radiator and lines get warm, so far they've room temp.
https://linustechtips.com/topic/465475-temp-issue-with-4690k/#findComment-6252393
run the intel xtu benchmark, only with manual voltage
what are the temps
Mainboard Asrock Z170 OCF CPU 6700k RAM Tridentz 3600 HDD Intel 730 240gb GPU GTX 780ti sc acx PSU Silverstone Strider 1200W  Case Antec 900 Laptop Lenovo Thinkpad T520 build log-   http://linustechtips.com/main/topic/35809-antec-900-the-re-birth-of-a-legend/ Check out the Tech Center https://www.youtube.com/user/prokon24/videos LTT's Unicore King
https://linustechtips.com/topic/465475-temp-issue-with-4690k/#findComment-6252659
what are the temps
I'm stuck in adaptive for Gigabyte reasons. But my voltage peaks at 1.236v. In XTU I'm in the high 60s with peaks in the low 70s. Pretty much what I had before. It's the medium loads that are higher than before. Things like cinebench and CPU demanding games.
https://linustechtips.com/topic/465475-temp-issue-with-4690k/#findComment-6252808
