Hi all,
I am just starting a new custom loop build (see screenshot for the goodies).  I am starting by testing the components to make sure they post - can I test for post with the water block on, without water running through it?  Or will there be insufficient cooling (or damage the water block)? Bearing in mind that it will be on for less than a minute.  I have an old intel stock cooler lying around, but can't really be bothered to put it on with new thermal paste, then take it off in the space of 5 mins (I also don't have any isopropyl handy).
What is everyone's opinions?
Thanks,
Rich
post-243662-0-74895800-1444563938_thumb.
https://linustechtips.com/topic/465210-testing-for-post-with-water-block/
Hi all,
Thanks,
Rich
I don't know but I hope all goes well and good luck with the build
Put on the intel heat sink.
You DO NOT want to fry your CPU!
The new i7's doesn't come with any heatsink.
You are fine to post the system and alike without a heatsink on, but you really want one if the system is going to run any longer than a minute or two.
Read his post.
He has a stock intel heatsink
I'll put the stock on - I'm just a little lazy but no point in risking anything!  I think I've found a place I can buy IPA nearby so I'll probably go get some there and just put a little thermal paste in. I might as well flash the mob's bios before it goes in, in case anything goes wrong with that.  Apparently you can flash over the internet now, what an age we live in!
I'd very definitely use a cooler for the POST - particularly if you have to spend any length of time troubleshooting.
For my upcoming (Real Soon Now!) 5820K build, which will be water cooled, I bought an air cooler specifically for POSTing - I expect to re-use that cooler elsewhere in the future, but even if I don't, it's relatively cheap insurance.
When you flirt with Death, you run the risk that Death has something more serious in mind.
CCIE #4206
Modern CPUs will throttle back and/or shutdown before any damage is done.
So you are fine to spend a few minutes getting a POST and checking in BIOS.
Just keep an eye on the temperature.
I speak my mind, sorry if thats a problem.
I've run my 4670k with no coolant running through my waterblock. No issues. Also ran a 4690k with no heatsink at all when testing for post on a Z87 board last week. No problems there either.
CPUs are hardier than most people think and well protected.
The New Machine: Intel 11700K / Strix Z590-A WIFI II / Patriot Viper Steel 4400MHz 2x8GB / Gigabyte RTX 3080 Gaming OC w/ Bykski WB / x4 1TB SSDs (x2 M.2, x2 2.5) / Corsair 5000D Airflow White / EVGA G6 1000W / Custom Loop CPU & GPU
The Rainbow X58: i7 975 Extreme Edition @4.2GHz, Asus Sabertooth X58, 6x2GB Mushkin Redline DDR3-1600 @2000MHz, SP 256GB Gen3 M.2 w/ Sabrent M.2 to PCI-E, Inno3D GTX 580 x2 SLI w/ Heatkiller waterblocks, Custom loop in NZXT Phantom White, Corsair XR7 360 rad hanging off the rear end, 360 slim rad up top. RGB everywhere.
