180mm max 750W PSU
Solved by quan289,
It's a good mid-range unit.
I would suggest the EVGA supernova 750w G2 instead, as it match your requirement of 180mm. It's a higher-end unit that is made to compete with units like the Seasonic X KM3, and you can get it in the same price range as the M12II Evo. https://uk.pcpartpicker.com/part/evga-power-supply-220g20750xr
Alternatively, the XFX XTR 750w would also be a solid choice, being a 170mm PSU that is based on the Seasonic G platform but with full moduarity, switch for semi-passive and active cooling, and a FDB fan. https://uk.pcpartpicker.com/part/xfx-power-supply-p1750bbefx
