Help me !
Go to solution Solved by You_are_a_cunt,
Unless you've damaged the acrylic, you should use non-alcohol based cleaning solutions. If you damaged it, you're screwezilla'd
Soap and detergent are your best bet.
On what surface exactly do you want to clean these?
There's no "one fix does it all", we need to know exactly what it is.
https://linustechtips.com/topic/462297-help-me/#findComment-6204312
I dont get it. What do you mean ?
Is this a phone? Tablet? Just a plain glass window? A case side panel? Is it plastic? Glass? What IS IT. Your picture doesn't tell me ANYTHING.
https://linustechtips.com/topic/462297-help-me/#findComment-6204331
is that an acrylic side panel?
ive never worked with acrylic but perhaps windex? (any vinegar based glass cleaner sounds like a safe bet)
^^^ someone yell at me if thats a bad idea ^^^
Watch out for each other. Love everyone and forgive everyone, including yourself. Forgive your anger, forgive your guilt. Your shame. Your sadness. Embrace and open up your love, your joy, your truth, and most especially your heart.
-Jim Hensen
https://linustechtips.com/topic/462297-help-me/#findComment-6204337
D.VA coming soon™ xoxo
Gulliver Nokia Lumia 1320
Werkfern Nokia Lumia 520
Hydromancer Acer Liquid Z220
https://linustechtips.com/topic/462297-help-me/#findComment-6204378
Windex would actually damage the acrylic.
https://linustechtips.com/topic/462297-help-me/#findComment-6204379
And if nothing works, you can always just use sandpaper since this is an acrylic window.
https://linustechtips.com/topic/462297-help-me/#findComment-6204401
How to clean those cloudy like marks ? Thanks
https://linustechtips.com/topic/462297-help-me/#findComment-6204448
Unfortunately it looks like the surface got etched other than wet sanding and polishing it out with compound which is a very time consuming process, your best bet is to get a replacement window material and mod it in place if it doesn't fit with the original mounting.
https://linustechtips.com/topic/462297-help-me/#findComment-6208054
