First build
Go to solution Solved by Rian,
CPU Cooler: Noctua NH-U9S 46.4 CFM CPU Cooler  ($61.98 @ Newegg)
Motherboard: Asus MAXIMUS VIII HERO ATX LGA1151 Motherboard  ($219.99 @ SuperBiiz)
Storage: Crucial M500 240GB 2.5" Solid State Drive  ($84.99 @ Amazon)
Video Card: MSI Radeon R9 390 8GB Video Card  ($319.99 @ Amazon)
Case: Corsair 200R ATX Mid Tower Case  ($64.99 @ NCIX US)
Monitor: LG 25UM57-P 60Hz 25.0" Monitor  ($199.00 @ B&H)
Total: $1575.05
Generated by PCPartPicker 2015-10-05 23:53 EDT-0400
You'll definitely benefit from the 8GB of vram if you doing content creation.
Swapped out your PSU to a fully modular one so that you can put on custom cables in the future to make your pc even sexier on the INSIDE.
After using a variety of prebuilts for some years, I have decided to go ahead and build my own desktop. Does anybody have recommendations on the build and resources for what I should look out for when actually building it?
My budget: About 1500 USD.
What I will use this build for: Video editing using Premiere Pro (as well as other Adobe CC products), 3D graphics work, programming, and possibly some gaming.
I will be running a single monitor, the LG 25UM57-P, with another planned for the future.
I already have mice and keyboards, and can get a copy of Windows.
I am upgrading because my current setup is too slow when dealing with large video files and rendering.
I may, in the future, buy another GPU for SLI, but I am undecided on whether it's worth it.
I do not care about the looks, just the performance for my purposes.
PCPartPicker link: http://pcpartpicker.com/p/7TY96h
Also, I am not sure whether I will, but if I want to overclock what will I need. I would like everything to be ready just in case, but this is not a necessity to me.
˙ǝɯᴉʇ ɹnoʎ ƃuᴉʇsɐʍ ǝɹɐ noʎ 'sᴉɥʇ pɐǝɹ oʇ ƃuᴉʎɹʇ ǝɹɐ noʎ ɟI
https://linustechtips.com/topic/462258-first-build/
checks out fine, aside from the power supply being mehh.
so, swap out that PSU for something better, (something seasonic or EVGA G2 probably)
something to consider is getting X99 instead of Z170
the 6700K will do amazingly in most scenarios, but in rendering a 5820K (x99 platform) will perform about 20% better.
https://linustechtips.com/topic/462258-first-build/#findComment-6203582
It looks alright but here is what I would do:
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor ($350.00 @ Amazon)
CPU Cooler: Corsair H100i GTX 70.7 CFM Liquid CPU Cooler ($109.99 @ Mac Mall)
Memory: G.Skill Ripjaws 4 series 16GB (4 x 4GB) DDR4-3000 Memory ($134.99 @ Newegg)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive ($88.89 @ OutletPC)
Storage: Western Digital BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive ($149.99 @ Newegg)
Video Card: MSI Radeon R9 390 8GB Video Card ($314.98 @ Newegg)
Case: NZXT S340 (Black) ATX Mid Tower Case ($68.99 @ SuperBiiz)
Power Supply: EVGA SuperNOVA NEX 750W 80+ Gold Certified Fully-Modular ATX Power Supply ($89.99 @ NCIX US)
Total: $1527.81
Generated by PCPartPicker 2015-10-05 23:39 EDT-0400
The 390 has better performance than the 970, and the WD black I think is better suited for your purposes. Everything else are just minor changes.
https://linustechtips.com/topic/462258-first-build/#findComment-6203596
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor  ($326.99 @ NCIX US)
CPU Cooler: Noctua NH-D14 65.0 CFM CPU Cooler  ($74.99 @ NCIX US)
Motherboard: Asus Z97-A ATX LGA1150 Motherboard  ($129.99 @ Amazon)
Memory: Crucial Ballistix Sport 8GB (2 x 4GB) DDR3-1600 Memory  ($44.49 @ Amazon)
Storage: Kingston Savage 240GB 2.5" Solid State Drive  ($89.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($52.99 @ Newegg)
Power Supply: Cooler Master VSM 750W 80+ Gold Certified Semi-Modular ATX Power Supply  ($109.99 @ Newegg)
Total: $1214.41
Generated by PCPartPicker 2015-10-05 23:46 EDT-0400
Win8.1 can be purchased for $30 from G2A.com
(Read my Sig)
https://linustechtips.com/topic/462258-first-build/#findComment-6203632
Total: $1527.81
It's a little pricey by the time I add in the monitor (accidentally forgot to put it in the list and had to edit), but I'll switch to the 390 as well as the PSU and SSD. For the cooler, is there anything I need to know about liquid cooling (how much maintenance?). Is it worth the extra $50? Do I need it?
EDIT: Just noticed the changes, sorry.
https://linustechtips.com/topic/462258-first-build/#findComment-6203654
Woah. Do you really need that motherboard? I'd spring for something cheaper, since you probably won't use half the features on that board.
That, and everything @Killervolt suggested.
EDIT- You don't need the H100i for a Skylake. The Noctua NH-D14 would be perfect.
GAMING PC "Ol' Bessie":
Ryzen 7 7800X3D | Radeon RX 9070 XT | Gigabyte B650M AORUS Elite AX | G.Skill Flare X5 6000MT/s CL36 16GBx2 | 5TB of SSD POWER | EVGA SuperNOVA 850W GT | Noctua NH-U14S | Fractal Design Pop! Mini AirCachyOS
Kind Of A Home Lab "Bay":
Ryzen 9 5900XT | Intel ARC A310 | ASUS PRIME B550-PLUS | T-FORCE 3200MT/s 16GBx2 + Corsair 3200MT/s 32GBx2 = 96GB!!! WOW!! | 2TB boot SSD + 8TBx6 HDD RaidZ2 | EVGA SuperNOVA 650W G2 | Phanteks Enthoo Pro M | Ubuntu 24.04 LTS
The Laptop:
Framework Laptop 13 | Intel i5-1340p | G.Skill Ripjaws 3200MT/s 16GBx2 | Solidigm P44 Pro 2TB | CachyOS
https://linustechtips.com/topic/462258-first-build/#findComment-6203655
Total: $1575.05
https://linustechtips.com/topic/462258-first-build/#findComment-6203693
Total: $1575.05
I like it. What's your recommendation: Win 8.1 or 10? I can wait a while till they work out the bugs.
https://linustechtips.com/topic/462258-first-build/#findComment-6203702
Here's what I think you should be using...
PCPartPicker part list: http://pcpartpicker.com/p/7jGPrH / Price breakdown by merchant: http://pcpartpicker.com/p/7jGPrH/by_merchant/
CPU: Intel Core i7-5820K 3.3GHz 6-Core Processor  ($379.95 @ SuperBiiz)
Motherboard: ASRock X99 Extreme6 ATX LGA2011-3 Motherboard  ($213.98 @ Newegg)
Memory: G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-3000 Memory  ($124.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($49.88 @ OutletPC)
Video Card: MSI GeForce GTX 970 4GB Twin Frozr V Video Card  ($328.49 @ SuperBiiz)
Power Supply: SeaSonic 650W 80+ Gold Certified Semi-Modular ATX Power Supply  ($90.98 @ Newegg)
Total: $1599.23
Generated by PCPartPicker 2015-10-06 00:00 EDT-0400
Im from Malaysia..... Wooooo!!! The land where 1 USD is 4.33 MYR...
PCPartPicker wont do for me...  :(
here's where I do my searching for stuff (Local Market and prices are in MYR): Lelong.my
https://linustechtips.com/topic/462258-first-build/#findComment-6203720
I MEANT 16 GB OF RAM. 16
8.1 It's free upgrade to 10 until next mid year so why go 10 with the extra money. Besides, it's only take you around 20 mins to upgrade and you can save a little
https://linustechtips.com/topic/462258-first-build/#findComment-6203920
Total: $1575.05
Just did a check on PCPartPicker, it flagged it as requiring more power if I added a second 390. Is there a better PSU, or is another 390 overkill?
https://linustechtips.com/topic/462258-first-build/#findComment-6239351
650 watts should be more than enough for the 390 system, even give you room to OC.
Unless you're planning to add another 390 in
https://linustechtips.com/topic/462258-first-build/#findComment-6239496
