This is my first build, and I'm going for a white/black color theme. I'm looking to use this PC for 1080p gaming on an ultra wide, specifically this model:
http://www.amazon.com/gp/aw/d/B00VBNQJSM/ref=mp_s_a_1_1?qid=1443788544&sr=8-1π=SX200_QL40&keywords=34um67&dpPl=1&dpID=41B0yGMXoHL&ref=plSrch.
The games I plan on are racing games, Skyrim(modded), Crysis, Assassin's Creed, Far Cry, and others.
Finally, here is the build:
http://pcpartpicker.com/p/ztBZYJ
Note: I know this build cannot overclock.
Also the budget is ~750 dollars, going under would be great.
https://linustechtips.com/topic/461823-first-build-need-assistance/
I would get an r9 380 (preferably with 4gb) instead of the gtx 960.
And get a different powersupply, the cx series are not the best.
A few options for powersupply:
http://pcpartpicker.com/part/xfx-power-supply-pro650wp1650snlb9
http://pcpartpicker.com/part/cooler-master-power-supply-rs550amaag1
Suggestion for graphics card:
http://pcpartpicker.com/part/sapphire-video-card-100384nt4gocl
1) Kill the PSU with fire. Low ambient temperature. Get a XFX or SeaSonic and or EVGA B2 PSU instead.
2) The ssd is like a expensive HDD. Get a Samsung 850 Evo
3) Get an R9 380 SAPHIRE 4G. The 380 is better then the 960, and can utilize the 4GBs of VRAM.
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
throw in just a little extra and your seagate barracuda could be 3TB instead of 1
and that psu though, give yourself some headroom if your getting an sli capable mobo.
Edit:
$100au could get you a boot ssd as well.
Hey look, my signature is invisible!
Interesting.
I love how nobody on the desktop side cares about power consumption apart from me.
I would change a few things.
1. i5-4570S (S SKU denotes a lot lower power at slightly lower performance (1-3 fps). )
2. I would get a R9 380 instead of a 960 if you can
3.That SSD is quite unnecessary and instead that money should be spent on better GPU.
4. Pick a power supply which has like 1.5x more power than what PC part picker says. Because power supplies run best at half capacity so go for around 650w (also just for future upgrades since otherwise you'll need a better PSU eventually).
Here's my PC specs: http://pcpartpicker.com/user/AluminiumTech/saved/t9xqqs
Judge a product on its own merits AND the company that made it.
How to setup MSI Afterburner OSD | How to make your AMD Radeon GPU more efficient with Radeon Chill | (Probably) Why LMG Merch shipping to the EU is expensive
Oneplus 6 (Early 2023 to present) | HP Envy 15" x360 R7 5700U (Mid 2021 to present) | Steam Deck (Late 2022 to present)
Mid 2023 AlTech Desktop Refresh - AMD R7 5800X (Mid 2023), XFX Radeon RX 6700XT MBA (Mid 2021), MSI X370 Gaming Pro Carbon (Early 2018), 32GB DDR4-3200 (16GB x2) (Mid 2022
Noctua NH-D15 (Early 2021), Corsair MP510 1.92TB NVMe SSD (Mid 2020), beQuiet Pure Wings 2 140mm x2 & 120mm x1 (Mid 2023),
PSU´s never should run at their capacity Limit. Get one that has 150w+ what your system actual need.
CPU i7 6700k MB  MSI Z170A Pro Carbon GPU Zotac GTX980Ti amp!extreme RAM 16GB DDR4 Corsair Vengeance 3k CASE Corsair 760T PSU Corsair RM750i MOUSE Logitech G9x KB Logitech G910 HS Sennheiser GSP 500 SC Asus Xonar 7.1 MONITOR Acer Predator xb270hu Storage 1x1TB + 2x500GB Samsung 7200U/m - 2x500GB SSD Samsung 850EVO
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor  ($175.88 @ OutletPC)
Motherboard: MSI Z97 PC MATE ATX LGA1150 Motherboard  ($77.85 @ OutletPC)
Storage: Mushkin ECO2 120GB 2.5" Solid State Drive  ($49.89 @ OutletPC)
Video Card: MSI Radeon R9 380 4GB Video Card  ($209.99 @ Newegg)
Case: NZXT S340 (White) ATX Mid Tower Case  ($68.99 @ SuperBiiz)
Power Supply: EVGA 500W 80+ Bronze Certified ATX Power Supply  ($44.99 @ Newegg)
Total: $721.96
Generated by PCPartPicker 2015-10-05 07:51 EDT-0400
I see you're going for a black and white build, so I tried my best to adhere to that colour scheme while getting you better parts for less money.
CPU: Intel Core i5-4590S 3.0GHz Quad-Core Processor ($199.98 @ NCIX US)
Motherboard: ASRock B85M Micro ATX LGA1150 Motherboard ($59.98 @ Newegg)
Memory: Kingston HyperX Fury White 8GB (2 x 4GB) DDR3-1866 Memory ($48.99 @ Amazon)
Storage: Western Digital BLACK SERIES 1TB 3.5" 7200RPM Internal Hard Drive ($69.99 @ Newegg)
Video Card: Gigabyte Radeon R9 380 4GB Video Card ($224.98 @ Newegg)
Case: NZXT S340 (White) ATX Mid Tower Case ($69.99 @ Amazon)
Power Supply: EVGA SuperNOVA G2 550W 80+ Gold Certified Fully-Modular ATX Power Supply ($89.99 @ Amazon)
Total: $763.90
Generated by PCPartPicker 2015-10-05 07:45 EDT-0400
I would use 16gb if you plan to play Ubisoft games but apart from that then it's good. And the 2.9Ghz for $20 less is a better deal. 100Mhz makes no difference.
Motherboard: ASRock H97M PRO4 Micro ATX LGA1150 Motherboard  ($79.89 @ OutletPC)
Memory: Corsair Vengeance 8GB (2 x 4GB) DDR3-1600 Memory  ($39.99 @ Newegg)
Storage: Sandisk SSD PLUS 120GB 2.5" Solid State Drive  ($46.99 @ Amazon)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($49.88 @ OutletPC)
Video Card: Sapphire Radeon R9 380 4GB Nitro Video Card  ($198.98 @ Newegg)
Case: NZXT S340 (Black) ATX Mid Tower Case  ($68.99 @ SuperBiiz)
Power Supply: EVGA 750W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($44.99 @ NCIX US)
Total: $705.59
Generated by PCPartPicker 2015-10-05 09:46 EDT-0400
The site has changed....
Alright, I have listened to the recommendations, and this is the build I created with all of your suggestions:
http://pcpartpicker.com/p/NVyKrH
Due to the resounding suggestion of the Sapphire R9 380, I replaced the 960 with that. Also, I replaced the motherboard with a cheaper model so I could afford an extra 1TB of HDD storage. The money saved also went into the PSU, which needed an upgrade as well. The PSU now has way more wattage, as well as a Gold efficiency certification. While I would've liked to have more RAM, I didn't feel like it was as necessary as the other upgrades, and wasn't worth the extra 40 dollars for me. Maybe down the road I will upgrade my RAM.
As a last note, does anyone have a recommendation for a wireless adapter?
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($229.99 @ SuperBiiz)
Motherboard: MSI Z97S SLI Krait Edition ATX LGA1150 Motherboard  ($125.99 @ SuperBiiz)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($88.89 @ OutletPC)
Video Card: Sapphire Radeon R9 380 4GB Nitro Video Card  ($213.98 @ Newegg)
Total: $853.57
Generated by PCPartPicker 2015-10-05 23:22 EDT-0400
Since no budget is stated i assume this would be okay?
You can keep the Krait since you're building a Black & White.
Get an unlocked CPU instead, you can use the stock cooler and not overclock (at the moment) and grab a decent air cooler for mild OC or a AIO for better OC.
Way better PSU for your OC needs.
You can always grab a 50 bucks HDD 1 or 2 weeks later. As a SSD will really improve the overall speed of your pc.
