Motherbord ASUS MAXIMUS VI HERO CPU INTEL i7 Processor 4770 Ram  HyperX Fury Black  GPU Asus NVIDIA GeForce GTX 980 4GB DDR 5  C drive  SAMSUNG 2.5" SATA III 850 PRO D deivr Seagate Barracuda 3.5 7200rpm 3 TB Powersupply COOLER MASTER V850 Full Modular
pleas let me know if my components are ok
cox i need to know this is my first gamming pc build
https://linustechtips.com/topic/461325-my-first-pc-build/
Use pcpartpicker, it helps everyone and it will tell you if your components are compatable.  Welcome to LTT.
The parts sound fine (idk what ram your talking about).
The Canadian Version Of Everything
-Made In Canada
https://linustechtips.com/topic/461325-my-first-pc-build/#findComment-6190293
Welcome to the forums! :D
Always follow your topics, quote or tag us to get some attention and mark your topics as solved when you are done ;)
Enjoy your stay
@mohamed123 We'll need a location (country is more than enough) and a budget in your local currency. Also, if you are not from the US/UK/Australia/New Zealand/Spain/Germany, give us a link to the store you'll buy the parts from.
Edited by JoaoPRSousa
"an obvious supporter of privacy"
https://linustechtips.com/topic/461325-my-first-pc-build/#findComment-6190318
