Hi! I saw this at a local shop
http://www.newegg.com/Product/Product.aspx?Item=N82E16826977008
and I can't justify spending that much money for a mouse pad. It looks and feels great, sure. But I can spend that money elsewhere. My desktops needs more ram and HDD's and I have other hobbies too.
Do you guys have DIY solutions? I'd love to hear them! I want to make my own that exactly covers my keyboard (Corsair K65) and mouse
i5 4670k | Noctua NH0-U12S | Asus Z97M Plus | Kingston HyperX Fury 8gb | Palit GTX 980 Ti Super Jetstream 6G | Samsung 850 EVO 250gb
WD Caviar Blue 1tb | Seasonic M12II 850W | Fractal Design Define R5 | Dell U3014 1600p 30" 60Hz
Corsair K65 | Razer Orochi | Bose QuietComfort 15 | Creative SBS A350 2.1
https://linustechtips.com/topic/459419-diy-mouse-pad-solutions/
piece of cardboard works fine. If you are feeling adventurous, grab some cloth and use spray-adhesive to mount it to the cardboard.
https://linustechtips.com/topic/459419-diy-mouse-pad-solutions/#findComment-6165198
Cut up an old T-shirt and wrap it around a piece of cardboard.
i5-4690k@4.5GHz || MSI GTX 970 || MSI z97 Gaming 5 || NZXT Kraken x61 || WD Black 1TB || Crucial MX100 || 8GB Corsair Vengeance Pro || Corsair RM750 || NZXT H440 || Corsair k70 RGB mx browns || Acer H236HL || ViewSonic VX2255wm-4
https://linustechtips.com/topic/459419-diy-mouse-pad-solutions/#findComment-6165206
Walmart has mouse pads for $3.
Edit: Nevermind Philippines
LTT's Fastest single core CineBench 11.5/15 score on air with i7-4790K on air
Main Rig
CPU: i7-4770K @ 4.3GHz 1.18v, Cooler: Noctua NH-U14S, Motherboard: Asus Sabertooth Mark 2, RAM: 16 GB G.Skill Sniper Series @ 1866MHz, GPU: EVGA 980Ti Classified @ 1507/1977MHz , Storage: 500GB 850 EVO, WD Cavier Black/Blue 1TB+1TB,  Power Supply: Corsair HX 750W, Case: Fractal Design r4 Black Pearl w/ Window, OS: Windows 10 Home 64bit
Plex Server WIP
CPU: i5-3570K, Cooler: Stock, Motherboard: ASrock, Ram: 16GB, GPU: Intel igpu, Storage: 120GB Kingston SSD, 6TB WD Red, Powersupply: Corsair TX 750W, Case: Corsair Carbide Spec-01 OS: Windows 10
Lenovo Legion Laptop
CPU: i7-7700HQ, RAM: 8GB, GPU: 1050Ti 4GB, Storage: 500GB Crucial MX500, OS: Windows 10
https://linustechtips.com/topic/459419-diy-mouse-pad-solutions/#findComment-6165211
I was thinking of that but cardboard is rough and gets damaged. Maybe I'll try the cloth thing. Microfiber is nice!
A stack of paper, tape it down to the desk and it works great.
It's my own solution for one of my cheaper systems where I can't be bothered to spend money on a real mousepad.
How about Formica board? Maybe I'll use a long sheet of black art paper (stiffer than usual)
https://linustechtips.com/topic/459419-diy-mouse-pad-solutions/#findComment-6165212
My problem with this technique is washing. I guess I can laminate the cardboard and then wrap cloth around it. So it's washable!
Sucks, haha. Last I checked, the only cheap mousepads here have ugly/funky designs. I just want a plain black one.
I got a 75cm one on ebay for $10. Non brand name.
That's exactly the length I need! Too bad I can't find any :( I just posted in our local Facebook group if they have any idea for generic ones
https://linustechtips.com/topic/459419-diy-mouse-pad-solutions/#findComment-6165262
Use a fancy cloth place mat or a regular one depending on how you want your mouse to slide around.
You're right O_O Thanks for that tip :D !
https://linustechtips.com/topic/459419-diy-mouse-pad-solutions/#findComment-6165269
http://www.ebay.ca/itm/171496496885?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
https://linustechtips.com/topic/459419-diy-mouse-pad-solutions/#findComment-6165277
Thanks a lot bud :D
i was able to find a regular sized black cloth mousepad for 2 dollars at a target.
Ahhh. Can't help but get jealous of Americans haha. You guys have the best computer market imo
https://linustechtips.com/topic/459419-diy-mouse-pad-solutions/#findComment-6165311
