Air or water?
The Noctua NH-D15 is one of the quietest and best performing coolers on the market, period.
The best performing cooler, is the Reeven Okeanos, but its loud, like, pretty damn loud.
The raijintek is a great cooler, but expensive for what you pay. If you're willing to, it will perform about the same, if not a bit better if you drop some good fans on it than a noctua nh-d15. But it also comes with more points of failure, adding in a pump to the mixture.
I've gone water, and haven't looked back, but as a PSA about 30 minutes ago I finished cleaning my 240x60mm rad for the 4790k, because i noticed I was hitting 75c on light use. Turns out, living in a house with 4 cats and 3 dogs means no matter how hard i try, after two months its going to be more dusty than the vatican secret library.
