If you want to buy a good wireless mouse I would sugget spending more than $20 because anything around that price range is pretty bad. If you are really on a budget you should buy a cheap mouse on amazon for a few bucks and save your money for a real upgrade in the future like the MX Master.
https://linustechtips.com/topic/459281-wireless-mouse/#findComment-6163447
So I want to buy the Logitech MX Master Wireless Laser Mouse, but it is kind of out of my budget zone. The thing that grabs me is the fact you can charge with a cable instead of using batteries. So is there any other mouses that is similar in the 20 dollar range? Thank you
sensi wireless?
https://linustechtips.com/topic/459281-wireless-mouse/#findComment-6163465
the M705 is not bad. i had 3 for 7 years and they work like they are new. i have to change the battery every 5 months but thats a long time imo
Check out my iCUE Guide Beta Tester for Corsair
Got a Corsair Product? Got a Question?
Feel Free to PM Me ?
https://linustechtips.com/topic/459281-wireless-mouse/#findComment-6163668
