Using GPU Boost for my 980 Ti
Solved by SkilledRebuilds,
I can put the slider to 2177 actually, so yes it is.
Ah, so as long as I have the ASUS GPU Tweak, it will automatically do it for me?
If you moved the slider, thats not GPU boost 2.0 doing the work, but you overclocking......and YOUR overclock setting is pushing that.
Remove the OC (Default/0) and GPU boosts will default boost to where it should.
/You do NOT need to do anything, OR..have anything open for it to work.
Understanding GPUBoost
