I built a gaming rig 6 months ago and I'm starting to have some issues already.
Sometime I loose connection with my mouse, keyboard and headset. It usually last only 5-10 sec, but it is very annoying when in game.
I'm not 100% sure but I think I also loose wii-fii, though that could be server issues.
But the most annoying thing is when my sreen says ''no signal detected''. That one only happens when I turn on my PC and it usually goes away after 20 min of messing with the cables.
I have a display port cable for 1440p plugged on GPU and HDMI cable plugged on Mobo. When this happens, neither work.
What you guys think? Could that be the motherboard or something else?
My build : https://ca.pcpartpicker.com/user/AcMaiden/saved/#view=KKPcCJ
P.S. When I test the screen with my other PC, the screen works just fine.
https://linustechtips.com/topic/459122-problem-with-my-motherboard/
it may just be graphics drivers and you may need to just reinstall
<p>Wish I could have this already!! : http://pcpartpicker.com/p/qTLRjX
