I'm struggling between deciding between java and c++ now...
C++ ... Or java ...
For desktop development, needs run on linux. I pretty much decided on C++ then decided java is good too and I'm stuck in the middle again.
Please tell me which you recommend and reply with reasons why.
CLARIFICATIONS: Not new to programming, I've used python for a few years. Also, I don't really care what is easiest.
I'd say learn Java first, then C++
Java is a much friendlier language.
PSU Tier List | CoC
Gaming Build | FreeNAS Server
java is horrible
the syntax is horrible
the entire code is horrible
the only reason its so popular is because it was was adopted by some large companies and now tons of stuff uses it
but seriously, if you have used any other coding language you will understand why java is just plain bad
I was also thinking about the same thing as OP recently. I want to get into engineering in the future and I've heard that it's useful to know a programming language for that field. I'm not sure which language to learn though :\
Sorry if I'm hijacking OP's thread, but what would you recommend I should learn for my purposes? I've never learned a programming language before and have pretty much zero experience with programming.
I actually couldn't underclock my 5 year old GPU to make it as slow as a next-gen console.
#pcmasterraceproblems
~Slick
I don't care whats easier, I'll figure it out anyways. I've used python for a long while.
java is horrible
Leaning to c++ again lol
C++. More power, but also more responsiblity. JAVA is easier, but C++ has more to offer. Both are cross platform languages but Java works natively with Android. C++...not so much
I'm looking for whats better, not easier here. I'll learn it anyways if its hard.
I almost always recommend python or js to beginners
if you want an easy language use python over java but c++ is better than either so learn that
https://linustechtips.com/main/topic/631048-psu-tier-list-updated/ Tier Breakdown (My understanding)--1 Godly, 2 Great, 3 Good, 4 Average, 5 Meh, 6 Bad, 7 Awful
yup python is great for beginners
if you want a steeper learning curve c++ is great, and you can do a lot more with it :)
My programming knowledge:
(small amount) LUA, then HTML & CSS, then Java (Still working on it tho)
I know python. I'm moving to a bigger language.
yeah saw that after
Java!
CPU: Intel i5 4690k @ 4.3 GHz       GPU: MSI GTX 980                      Cooling: be quiet! Pure Rock                     OS: Windows 7            Monitor: BenQ XL2411Z
Motherboard: AsRock Z97 PRO4   PSU: Corsair 600W CX600M       Keyboard: Razer BlackWidow Ultimate   SSD: Intel 120GB 520   Headset: HyperX Cloud II
RAM: 12GB Crucial Ballistix            Case: Corsair 750D                       Mouse: Logitech G502                         HDD: Seagate 1TB        Speakers: Audioengine A5+
C# is the devil. (*typed whilst installing C# compiler*)
But this language requires copious ammounts of code to do simple things.
wait w0t
its basically the same thing as java/c++ lol if not slightly easier
java is horrible
I liked Java :unsure:
PSU Tier List | CoC
have you done stuff other than java?
C and C++
PSU Tier List | CoC
