Hey people
I need to build a pc for my grandmother. And it has to cost like 600 NZD or less if possible. I don't know much about this price range and this older tech so help is appreciated. I need to save like 150NZD right now. She will use it for video streaming, skype and email thats it. So ideas?
http://nz.pcpartpicker.com/p/KxF7NG
ps. do i need the video card or does the chip have integrated graphics i dont know ....
"God created war so that Americans would learn geography"
https://linustechtips.com/topic/458272-pc-help-how-to-make-it-cheaper/
Drop the aftermarket CPU cooler, pick a case that has built-in PSU (only if budget is really tight). I think the integrated graphics on that will be fine. Also, add a webcam if she uses it for skype.
Use an aftermarket CPU if you don't add a GPU though.
ROG X570-F Strix AMD R9 5900X | EK Elite 360 | EVGA 3080 FTW3 Ultra | G.Skill Trident Z Neo 64gb | Samsung 980 PRO
ROG Strix XG349C Corsair 4000 | Bose C5 | ROG Swift PG279Q
Logitech G810 Orion Sennheiser HD 518 |  Logitech 502 Hero
what kind of gpu and is the pentium g3240 aftermarket?
looks like we're entering APU territory, hang on.
EDIT: Here:
CPU: AMD A10-7850K 3.7GHz Quad-Core Processor  ($198.00 @ 1stWave Technologies)
Motherboard: ASRock FM2A88M-HD+ Micro ATX FM2+ Motherboard  ($89.00 @ 1stWave Technologies)
Memory: Kingston Savage 4GB (1 x 4GB) DDR3-2400 Memory  ($59.87 @ Aquila Technology)
Case: Silverstone PS08B (Black) MicroATX Mid Tower Case  ($69.43 @ Ascent Technology)
Power Supply: Corsair CX 430W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($107.00 @ Paradigm PCs)
Total: $609.63
Generated by PCPartPicker 2015-09-29 19:10 NZDT+1300
Aftermarket 980Ti >= Fury X >= Reference 980Ti > Fury > 980 > 390X > 390 >= 970 380X > 380 >= 960 > 950 >= 370 > 750Ti = 360
"The Orange Box" || CPU: i5 4690k || RAM: Kingston Hyper X Fury 16GB || Case: Aerocool DS200 (Orange) || Cooler: Cryorig R1 Ultimate || Storage: Kingston SSDNow V300 240GB + WD Black 1TB || PSU: Corsair RM750 || Mobo: ASUS Z97-A || GPU: EVGA GTX 970 FTW+
"Unnamed Form Factor Switch" || CPU: i7 6700K || RAM: Kingston HyperX Fury 16GB || Case: Phanteks Enthoo Evolv Mini ITX (White) || Cooler: Cryorig R1 Ultimate (Green Cover) || Storage: Samsung 850 Evo 1TB || PSU: XFX XTR 550W || Mobo: ASUS Z170I Pro Gaming || GPU: EVGA GTX 970 FTW+
haha okay
build above, should be good if you don't OC the chip (high frequency ram assists the iGPU, and I think 4GB should be enough)
G3258 can handle 1080p fine. What I was saying aftermarket is the cooler Master.
CPU: Intel Pentium G3258 3.2GHz Dual-Core Processor  ($109.95 @ Computer Lounge)
Motherboard: Gigabyte GA-H81M-S2PV Micro ATX LGA1150 Motherboard  ($79.34 @ PB Technologies)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1600 Memory  ($89.00 @ 1stWave Technologies)
Storage: Crucial BX100 120GB 2.5" Solid State Drive  ($90.85 @ PB Technologies)
Total: $545.57
Generated by PCPartPicker 2015-09-29 19:28 NZDT+1300
The cheapest way would be buying used parts. You should check what you could locally get. Keep an eye also on used office pcs like Dell Optiplex. Those can get pretty cheap because of limited upgradability, but even a C2D could handle tasks needed.
CPU: Intel Core i3-4170 3.7GHz Dual-Core Processor  ($189.75 @ PB Technologies)
Memory: Crucial 4GB (1 x 4GB) DDR3-1600 Memory  ($42.00 @ 1stWave Technologies)
Case: Cooler Master Elite 361 ATX Mid Tower Case  ($65.00 @ Wiseguys)
Total: $573.94
Generated by PCPartPicker 2015-09-29 19:40 NZDT+1300
