HTML/CSS Help :(
Go to solution Solved by The Pizza Thief,
Yea, fuk, i tried a different uploading (used imgur and the resolution for the pic was 4k lol)
I think i should use imgur instead of the other shitty website i was uploading pics on
Yup, Imgur is all I use.
Le wallpaper wont scale up with the backround
http://taskforce163.bbforum.co/
is the website
[the body]
html, body {
color: #CCCCCC;
        background-repeat: no-repeat;
        background-attachment: fixed;
https://linustechtips.com/topic/458212-htmlcss-help/
You just changed something? Cause now it's all zoomed into the soldier.
https://linustechtips.com/topic/458212-htmlcss-help/#findComment-6149105
https://linustechtips.com/topic/458212-htmlcss-help/#findComment-6149121
