PLANING TO MAKE THIS PC FOR LEAGUE OF LEGENDS AND TROVE ALSO FOR SCHOOL
CPU: Intel Core i3-4160 3.6GHz Dual-Core Processor  ($102.99 @ SuperBiiz)
Motherboard: ASRock H97M PRO4 Micro ATX LGA1150 Motherboard  ($69.98 @ Newegg)
Video Card: MSI GeForce GTX 750 Ti 2GB TWIN FROZR Video Card  ($111.99 @ SuperBiiz)
Power Supply: EVGA 600B 600W 80+ Bronze Certified ATX Power Supply  ($49.99 @ Newegg)
Total: $513.71
Generated by PCPartPicker 2015-09-28 17:35 EDT-0400
https://linustechtips.com/topic/458019-first-pc-build/
Total: $497.81
Generated by PCPartPicker 2015-09-28 17:15 EDT-0400
what are you using for os ?
The Ninja (current gaming pc)  Case- h440 red/black cpu- i5-4690k@ 4.3ghz cooler- coolermaster hyper 212 evo moboGigabyte z97x-sli ram- adata xpg v.1 2x4gb 1600mhz gpu- asus strix gtx 970 hdd- wd blue 1tb ssd- kingston hyperx savage 240gb psu- evga 600b peripherals: mouse- razer death adder 2013 keyboard- corsair k70 with chery mx-reds headset- HyperX Cloud 2
my laptop- toshiba satelite p850, cpu- i7-3630qm ram- 8gb 1600mhz hdd- 1tb 5400rpm gpu- Nvidia gt630m 2gb
did you know we have a gun thread ? well we do
and a car thread !
https://linustechtips.com/topic/458019-first-pc-build/#findComment-6146337
Get rid of the CX
https://linustechtips.com/topic/458019-first-pc-build/#findComment-6146338
Instead of the i3 try the G3258 pentium, same dual core, cheaper, and has a lot of over clocking room. It'll save you some money for a better cpu down the road. They both perform the same if not the g3258 better since of the overclockability.
The thing is, the i3 has hyperthreading.
USEFUL LINKS:
PSU Tier List F@H stats
https://linustechtips.com/topic/458019-first-pc-build/#findComment-6146350
i3 is about 30% better than the Pentium, OC or no OC - pentium stutters like a boss
https://linustechtips.com/topic/458019-first-pc-build/#findComment-6146360
That is mostly good, but the PSU and SSD are pretty bad. Get the XFX TS550 and this sandisk ssd instead.
No, just no. The i3s have hyperthreading, which makes them much better than a g3258. Unless you spend a lot on a good cooler, the i3 will crush it, and even the the g3258 will struggle to keep up.
https://linustechtips.com/topic/458019-first-pc-build/#findComment-6146368
i3s are minimum for gaming now, the Pentium is heavily reliant of OC otherwise it's pretty bad and it causes stutters also i3 has HT
        Setup
CPU: i3 4160|Motherboard: MSI Z97 PC MATE|RAM: Kingston HyperX Blue 8GB(2x4GB)|GPU: Sapphire Nitro R9 380 4GB|PSU: Seasonic M12II EVO 620W Modular|Storage: 1TB WD Blue|Case: NZXT S340 Black|PCIe devices: TP-Link WDN4800| Montior: ASUS VE247H| Others: PS3/PS4
https://linustechtips.com/topic/458019-first-pc-build/#findComment-6146374
That is mostly good, but the PSU and SSD are bad. Get the XFX TS550 and this sandisk ssd instead.
No, just no. The i3s haver hyperthreading, which makes them much better than a g3258. Unless you spend a lot on a good cooler, the i3 will crush it, and even the the g3258 will struggle too keep up.
This!
Even the Athlon X4 860K is better than the Pentium
https://linustechtips.com/topic/458019-first-pc-build/#findComment-6146376
        Setup
https://linustechtips.com/topic/458019-first-pc-build/#findComment-6146379
This!
      CPUIntel Core i7-4790K 4.8GHz Moherboard: MSI Z97 SLI Krait Edition Memory: HyperX FURY White 24GB DDR3 1866MHz GPU: Asus GTX 970 Turbo
             PSU: EVGA SuperNOVA 750w SSD: Crucial MX200 250GB HDDWB Blue 1TB Monitor: (2x) BenQ GL2460HM 24-Inch Case: NZXT S340 White
https://linustechtips.com/topic/458019-first-pc-build/#findComment-6146449
He forgot to mention that the Pentium stutters like hell cause of the 2 threads
https://linustechtips.com/topic/458019-first-pc-build/#findComment-6146461
anyone know how to get windows 8.1 for free without pirating
nope
and a car thread !
https://linustechtips.com/topic/458019-first-pc-build/#findComment-6146522
