Best monitor for 200$
danielhowk
This is a bit more but the asus pb238q (I think that's it's name) is a fantastic moniter
I would recommend to check out benq and asus monitors :)
@danielhowk
Just giving this as a choice. I like the Dell U2414H. (I'm getting it actually and am biased about it.)
https://pcpartpicker.com/part/dell-monitor-u2414h
It even has the full range of motions.
ASUS VS239H / MX239H Acer G257HL
ViewSonic VX2370SMH
4 of these which is better ?
ViewSonic VX2370SMH
I'm not sure.
Do you want a 23 inch or a 25 inch monitor?
I'm not sure.
probably want the low input lag and response time.
dont mind either 23-25 inch
It might not sound like a big difference, but seeing two in person changes my mind about it.
But if I'm wrong and you still don't care, then I guess you should just go for the cheaper one.
I can't really decide. I think the Acer G257HL looks good, but I kind of prefer Asus as a company. The  ASUS VS239H-P seems very glossy though.
I think the Acer G257HL.
But that's just my decision.
thanks , what monitor are u using?
Well I bought the  Dell U2414H a few days ago. Should arrive soon.
is the 8ms response time okay for you ?
I don't think I'm a good person to ask that question because I can't tell and I don't care.
I'm beginning to believe that the 1ms response time stuff is just a placebo. Either that or my eyes just can't see it.
I don't care because it takes 16ms for a frame to go by and 8ms is half that so it's good enough.
  • 2 weeks later...
i just saw a new released model by Dell UP2516D
i was deciding between U2515H and U2415 . which is better for gaming ? i know you mentioned H aspect ratio of 16:9 could be better for gaming .  but U2415 : 1920x1200/6ms/IPS
and U2515H : 2560x1600/8ms/ AH-IPS
which would be better one have higher resolution but higher response time and AH ips.
and should i be waiting for UP2516D ?
thanks
thanks
You should make a new thread about that.
