where does this cable connect to
Go to solution Solved by Speedbird,
That plugs into your PSU!
Yes, to the SATA power connector.
@Khav2
Plug that into the PSU and then the fans connect to the sockets which are connected.
This allows you to control the fans at the front of the case with the 3 way speed.
Helpful if your MB doesnt have more than 2/3 case fans.
CPU: i7 8700k   Motherboard: Asus Maximus Hero  RAM: 16GB @ 3600Mhz  GPU: MSI 980Ti 6G  Case: Fractal Design R5 (4 Intakes/3Exhausts)  Storage: Crucial BX100 SSD, Samsung 850 & Seagate 2TB HDD  PSU: Seasonic M12II Evo '850W'  CPU Cooling: Corsair H110i GT
sata power cable. in your ssd / hdd
from your power suply, not motherboard
It's a SATA power connector.
Connect a SATA power cable female to that.
Where's it come from?
EDIT:
This
@Speedbird
I have EVGA  supernova 750 G2 , could you please show me a pic so that i know where do plug it
Could this be the reason why i don't get POST
Make sure you've put your 8-pin CPU power into the MB/PSU. Same for the 20 etc.
SATA power for your drives
