put a magnet on a a table. Spread them around.
Thanks- and one more!
What is a uniform field and how can it be obtained?
its a field that has the same energy distribution all around. If they are the only thing in the universe they will be perfectly uniform, anything else close by will cause it to deform slightly.
A basic primer but covers (to a headline level) the salient points.
http://www.bbc.co.uk/education/guides/zxxbkqt/revision/2
Note this is the second page which includes uniform fields.
 Two motoes to live by   "Sometimes there are no shortcuts"
                                           "This too shall pass"
