Hello, I am helping my friend build his first gaming rig and it's been awhile since I have built one. (2000 USD)
I have some ideas but I would like input on what to get him.
He needs all peripherals excluding a headset, also he knows he wants a Razer DeathAdder and black widow (Both chroma)(He wants the mouse for sure but the keyboard can change).
This includes speakers, monitor, mouse, keyboard, operating system (Windows 10 would be nice).
He wants either a gtx 970, 980 or better (Suggestions). (Also he may get a second in the future but that doesn't affect the budget).
White and black is what he wants for a color scheme if possible. (He likes the Nzxt Phantoms but anything would be appreciated).
Any help would be appreciated, thank you for your time!
http://pcpartpicker.com/p/gK2YD3 (Just a little idea)
https://linustechtips.com/topic/454018-need-help-2000-max/
Motherboard: MSI Z97-Gaming 3 ATX LGA1150 Motherboard  ($159.89 @ OutletPC)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($89.49 @ OutletPC)
Video Card: MSI GeForce GTX 980 Ti 6GB Video Card  ($629.98 @ NCIX US)
Case: NZXT S340 (Black) ATX Mid Tower Case  ($68.99 @ SuperBiiz)
Monitor: Acer G237HLbi 60Hz 23.0" Monitor  ($159.98 @ OutletPC)
Keyboard: Razer BlackWidow Chroma Wired Gaming Keyboard  ($162.75 @ Other World Computing)
Mouse: Razer DeathAdder Chroma Wired Optical Mouse  ($66.80 @ Amazon)
Speakers: Cyber Acoustics CA-3602 30W 2.1ch Speakers  ($29.99 @ Amazon)
Total: $2051.34
Generated by PCPartPicker 2015-09-21 17:16 EDT-0400
this should do nicely also the Chroma's are a waste of money fyi
edit pick up a windows key from Reddit
https://linustechtips.com/topic/454018-need-help-2000-max/#findComment-6090362
mind turning down the size?
use pcpartpicker.com
Did and sorry meant to post a link.
Total: $2051.34
Damn, that was fast! I'll run it by him and see what he thinks.
https://linustechtips.com/topic/454018-need-help-2000-max/#findComment-6090385
 I
 I do not suggest Razer products. I will show him mine, they are made very cheap. Have him look in Mionix Castor, as for the keyboard I again sInce again, they are cheap for a reason. I highly suggest Corsair or Ducky ( and some may know I do not like Corsair )
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
https://linustechtips.com/topic/454018-need-help-2000-max/#findComment-6090389
2k is a really odd budget especially with peripherals, If he needs the price cut down. he could switch to a 1TB WD Blue instead of a 2TB WD Black
Also a 390x is a good alternative to a  980Ti
https://linustechtips.com/topic/454018-need-help-2000-max/#findComment-6090396
http://pcpartpicker.com/p/3K2YD3
Awesome all around build with White & Black theme, a great 1080p gaming monitor, even managed to get some pretty awesome speakers & a blu ray reader, which you may or may not use, if not you can drop it and get an even better monitor! I hope you consider this build and I hope your friend enjoys! Also 2$ under budget :D
Sergeant, United States Marine Corps
Network Administrator, Comptia A+, Security+, Cisco Certified Networking Associate
From a G3258 to dual Xeon E5-2670's
https://linustechtips.com/topic/454018-need-help-2000-max/#findComment-6090405
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor  ($239.99 @ Amazon)
CPU Cooler: Corsair H80i GT 70.7 CFM Liquid CPU Cooler  ($99.99 @ Amazon)
Motherboard: Asus Z170-A ATX LGA1151 Motherboard  ($159.99 @ SuperBiiz)
Memory: Kingston HyperX Fury Black 16GB (2 x 8GB) DDR4-2133 Memory  ($99.99 @ Newegg)
Storage: Hitachi Deskstar 2TB 3.5" 7200RPM Internal Hard Drive  ($62.95 @ Amazon)
Video Card: MSI GeForce GTX 980 4GB Video Card  ($496.06 @ Amazon)
Case: BitFenix Comrade ATX Mid Tower Case  ($58.99 @ SuperBiiz)
Power Supply: EVGA 750W 80+ Gold Certified Fully-Modular ATX Power Supply  ($99.99 @ Newegg)
Operating System: Microsoft Windows 10 Home OEM (64-bit)  ($97.89 @ OutletPC)
Monitor: Acer GN246HL 144Hz 24.0" Monitor  ($201.98 @ Newegg)
Speakers: Logitech Z506 155W 5.1ch Speakers  ($67.95 @ B&H)
Total: $2004.81
Generated by PCPartPicker 2015-09-21 17:23 EDT-0400
CPU: i5 6600k @ 4.6 ghz  Motherboard: Asus z170-a  Cooling: Corsair h80i GT GPU: EVGA GTX 970  Ram: G.Skill 2x8 gb ddr4 2400  PSU: EVGA G2 Supernova 550w  Case: Corsair 200r Storage: 250GB 850 EVO + 2x wd 1 tb drives
https://linustechtips.com/topic/454018-need-help-2000-max/#findComment-6090416
Not really lol. The 390x is a good alternative to the 980 as it performs similarly and costs slightly less, however the 980ti smokes both the 980 and 390x, as well as the Fury, and Fury X.
https://linustechtips.com/topic/454018-need-help-2000-max/#findComment-6090452
Keep in mind it costs some 240 dollars less too...
Also if you look at the next page the 390x gets a bit of an edge on 2k Theif and Witcher 3 and Shadow of Mordor
and I can go on :P you have to take into consideration the 200+ dollar price difference. As you can see I went 50 or so dollars over budget thats why I initially recommended it
lets face the fact tho
your build is better >.>
https://linustechtips.com/topic/454018-need-help-2000-max/#findComment-6090506
PCPartPicker part list: http://pcpartpicker.com/p/YzpRmG
Price breakdown by merchant: http://pcpartpicker.com/p/YzpRmG/by_merchant/
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($229.99 @ SuperBiiz)
CPU Cooler: Cooler Master Hyper 212 Plus 76.8 CFM Sleeve Bearing CPU Cooler  ($19.98 @ OutletPC)
Motherboard: Asus SABERTOOTH Z97 MARK S ATX LGA1150 Motherboard  ($269.00 @ B&H)
Memory: Kingston HyperX Fury White 16GB (2 x 8GB) DDR3-1866 Memory  ($83.99 @ Newegg)
Storage: Western Digital BLACK SERIES 2TB 3.5" 7200RPM Internal Hard Drive  ($116.91 @ Amazon)
Video Card: EVGA GeForce GTX 970 4GB Superclocked ACX 2.0 Video Card  ($319.99 @ Amazon)
Case: NZXT Phantom 410 (White) ATX Mid Tower Case  ($83.99 @ SuperBiiz)
Monitor: BenQ XL2420Z 144Hz 24.0" Monitor  ($319.99 @ Newegg)
Total: $1960.76
Generated by PCPartPicker 2015-09-21 17:43 EDT-0400
CPU: Intel i7 - 5820k @ 4.5GHz, Cooler: Corsair H80i, Motherboard: MSI X99S Gaming 7, RAM: Corsair Vengeance LPX 32GB DDR4 2666MHz CL16,
GPU: ASUS GTX 980 Strix, Case: Corsair 900D, PSU: Corsair AX860i 860W, Keyboard: Logitech G19, Mouse: Corsair M95, Storage: Intel 730 Series 480GB SSD, WD 1.5TB Black
Display: BenQ XL2730Z 2560x1440 144Hz
https://linustechtips.com/topic/454018-need-help-2000-max/#findComment-6090564
