Hello all,
I wasn't entirely sure where to put this, so it goes here! Anyway, what are a few good ways and companies to ask for a review sample of a product? (I'm planning on starting a tech YouTube Channel) Thanks!
BOINC Setup:
i5 7200U @ Stock
Core2Duo T6600 @ Stock
i3 2330M @ Stock
i5 3210M @ Stock
https://linustechtips.com/topic/453894-asking-for-a-review-sample/
go on their website and find the contact info, and contact them
wow.  if you can't figure that out by yourself or google it. good luck out there..
IF you are planning to start a tech channel I highly suggest that you review something that you currently own to show these companies you are serious in what you do. I have tried and they will not give you something because as of now you have nothing to prove that you are serious. You can truly review anything, a PC part in your system or a phone you just recently got. Anything to show you are willing to do it.
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
i think you need to prove to them that their product will actually be reviewed professionally and correctly, so if you where to do it on a youtube channel they'll go checkout your channel and see if it is 'worthy' of a review sample.
basically, you won't be getting free stuff very easily :P
|| Asrock Z68 Extreme 3 Gen 3 || i5 3570 @3.5GHz || Zalman CNPS10X Optima || 8GB RAM HyperX Fury Blue @ 1600MHz || Thermaltake Berlin 630W || Zalman Z11 || Gainward Phantom GTX 970 || 120GB Kingston V300  (Gift) + 1TB  WD Green
Phone: Xiaomi Redmi Note 8
Tablet: iPad Mini 2
I'm playing my Xbone on 3 LG Curved monitors-No one ever
Please, read CoC it helps, it helped me it should help you-Every competent member
Resident bad pun maker.....please excuse them
I knew that was one way of doing it, I just wanted to see if there was anything else.
BOINC Setup:
i5 7200U @ Stock
i3 2330M @ Stock
i5 3210M @ Stock
I guess my Mionix Naos 7000 and Acer XB270HU will be multi use peices of tech then.
BOINC Setup:
i5 7200U @ Stock
i3 2330M @ Stock
i5 3210M @ Stock
Your channel has to be popular to get review samples too. Most starter youtubers start by buying them out of pocket or borrowing them from someone.
Intel Core i7 7770K | 32 GB's Ram 3000MHz | GTX 1080 Ti | 250GB SSD | 3TB 7400 RPM | Sound Blaster Z | ASUS ROG MG278Q | Razer Blackwidow Chroma | Final Mouse 2015 | Blue Yeti | Seinheiser HD 600's | Beyerdynamic DT 990 Pro | Aune T1 MK2
