No, that 960 wont.
You're probably right about it not running ARK at playable frames (cough cough terrible optimization) , but on any other game that card will easily obtain 60 fps 1080p med-high settings, maybe even high-ultra.
CPU: i7 8700 GPU: Asus ROG Strix GTX 1080 Mobo: Gigabyte Z370 Gaming 5 Ram: 16GB EVGA SuperSC SSD: Samsung 850 EVO 250GB
HDD: Seagate Barracuda 2TB PSU: TX650M Case: NZXT S340 Elite OS: Windows 10 Mouse: Logitech G403 Mouse Mat: HyperX Fury S Pro XL
Keyboard: CM Masterkeys Pro S (reds) Headphones: Sennheiser HD598 Monitor: Asus 24' MG248QR Devices: IPhone 11 Pro Max + 13' Macbook Pro
https://linustechtips.com/topic/453865-first-gaming-pc-build/#findComment-6087929
I'm sayyinn max settings GTA5.
- CPU: Intel i7 3770 - GPU: MSI R9 390 - RAM: 16GB of DDR3 - SSD: Crucial BX100 - HDD: Seagate Barracuda 1TB -
https://linustechtips.com/topic/453865-first-gaming-pc-build/#findComment-6087934
No you cannot max that game 100%, but you need an overkill rig to do the advanced settings.
https://linustechtips.com/topic/453865-first-gaming-pc-build/#findComment-6087945
I would change out the ram for just 8 GB and get a GTX 970.
CPU: i7-8700K I CPU Cooler: Noctua NH-D15 GPU: ROG Strix 1080 Ti MoBo: ROG Strix Z370-E RAM:  G.SKILL Ripjaws V Series 32GB (2 x 16GB)   PSU: CORSAIR HXi Series HX1000i Case: Corsair Air 540 Display: 24" 1920X1080p 144Hz ASUS - 27" 2560X1440p 144Hz Dell OS: Windows 10 Home 64bit
https://linustechtips.com/topic/453865-first-gaming-pc-build/#findComment-6087946
I wouldn't really count the advanced settings as max, but other than that my 390 can run everything in normal settings tab on max.
https://linustechtips.com/topic/453865-first-gaming-pc-build/#findComment-6087955
http://pcpartpicker.com/p/KttHmG Will this PC run games like GTA 5 & Ark in 1080p 60fps?
nothing can run ark at 1080p 60fps but with gta my 650 ti can handle it in a mix of high and normal at 60fps
Main PC |CPU - i7-6700k|GPU - R9 290x tri-x 4gb|RAM - 16gb ddr4|MOBO - MSI z170 - A PRO|HDD - WD 1TB/240gb Sandisk |PSU - 700w Raidmax
Laptop |CPU - i7 4720hq|GPU - 960m 2gb|Ram - 8gb 2x4|Model - y50-70 Touch|SSD - 240gb Patriot drive|Display - 1920x1080 IPS touch
https://linustechtips.com/topic/453865-first-gaming-pc-build/#findComment-6087975
i would go with this
http://pcpartpicker.com/p/byN9D3
you can get windows of g2a for 30 bucks to save money. but spending the extra 30 is way worth it
https://linustechtips.com/topic/453865-first-gaming-pc-build/#findComment-6087995
$800
http://pcpartpicker.com/parts/partlist/
Check around and make sure the CPU won't bottleneck the 390 if it does you'll have to get a better CPU or downgrade the GPU, I understand if you want to go with a gtx card but with an 800 dollar budget an AMD would be better IMO.
CPU: I7 4790k  CPU Cooler: NH-D15 GPUMSI 970 4gb   Motherboard: z97 Gaming 5 PSU: Corsair hx850   Ram: Corsair Vengeance 8 gb  SSD: Samsung 850 Evo  Case: Air 540
https://linustechtips.com/topic/453865-first-gaming-pc-build/#findComment-6088064
Buy a cheaper copy of windows 8.1
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor  ($175.88 @ OutletPC)
Motherboard: ASRock H97M Anniversary Micro ATX LGA1150 Motherboard  ($67.89 @ OutletPC)
Memory: Kingston HyperX Fury Blue 8GB (1 x 8GB) DDR3-1866 Memory  ($41.99 @ Newegg)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($46.89 @ OutletPC)
Video Card: Gigabyte Radeon R9 390 8GB SOC Video Card  ($309.99 @ Newegg)
Case: NZXT S340 (Black/Blue) ATX Mid Tower Case  ($75.99 @ SuperBiiz)
Power Supply: SeaSonic 520W 80+ Bronze Certified Fully-Modular ATX Power Supply  ($65.99 @ SuperBiiz)
Operating System: Microsoft Windows 8.1 OEM (64-bit)  ($20.00)
Total: $804.62
Generated by PCPartPicker 2015-09-21 14:34 EDT-0400
7800X3D - MSI B650 MAG Tomahawk - 32GB 6000mhz CL30 - Gigabyte 3080 TI - 2TB NVME - 1000w PSU - ID Cooling 240mm AIO
https://linustechtips.com/topic/453865-first-gaming-pc-build/#findComment-6088941
CPU: Intel Core i5-4590 3.3GHz Quad-Core Processor  ($183.99 @ SuperBiiz)
Motherboard: Gigabyte GA-B85M-DS3H-A Micro ATX LGA1150 Motherboard  ($57.24 @ Newegg)
Memory: Mushkin ECO2 8GB (2 x 4GB) DDR3-1600 Memory  ($35.99 @ Newegg)
Video Card: MSI Radeon R9 390 8GB Video Card  ($329.98 @ SuperBiiz)
Case: Cooler Master N200 MicroATX Mid Tower Case  ($43.99 @ SuperBiiz)
Power Supply: EVGA 750W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($80.99 @ SuperBiiz)
Total: $779.07
Generated by PCPartPicker 2015-09-21 14:52 EDT-0400
BigDay
https://linustechtips.com/topic/453865-first-gaming-pc-build/#findComment-6089118
