Headset sound is messed up :(
Hello!
I recently formatted my pc because i changed Graphics card but now when i play games, my sound is flipped around for example gun sounds are comming out in the wrong side of the headset. I've never had this problem before with my headset and i've tried almost everything to fix it but with no luck.
At this point i have no idea what i could try to do to fix it so i hoped some of you guys maybe knew what i could do to fix this problem?
I'm using the headset "siberia raw prism" and i've also got the Steel series Engine installed.
post-188577-0-31451300-1442778648_thumb.
The right man in the wrong place can make all the difference in the world.
https://linustechtips.com/topic/453400-headset-sound-is-messed-up/
Hello!
got the right driver installed?
If you need remote help fixing something on your computer
I can help over Teamviewer if you wish
just msg me on my profile
And what do you want me to check in there?
Try to set everything to its default values
And you didn't had to format because you got a new graphics card, you only had to uninstall old and install new video drivers.
The stars died for you to be here today.
A locked bathroom in the right place can make all the difference in the world.
