Stock Cooler or nah?
Freeeeezy
For my first build I am getting an Intel Xeon E3 1231 v3, and this CPU, because it's meant for servers it runs a lot cooler and is locked so I cannot overclock it (Which I'm fine with). Because of this, I have decided not to upgrade to an aftermarket CPU cooler for function, but should I upgrade for aesthetics?
The stock Intel CPU fan would definitely be adequate for cooling my Xeon CPU, but would it be worth it to upgrade, to say a ARCTIC Alpine 11 Plus, just for aesthetics and acoustics?
My Baby Girl ❤️CPU: Ryzen 7 3700X | Mobo: ASRock B450 Pro4 ATX | RAM: 2 x 8 GB DDR4 3200 MHz GPU: EVGA GTX 1070 SC | Case: Fractal Design Core 3500 | HDD: Seagate 1TB SSD: Adata SP900 512GB PSU: EVGA 650G 80+ Gold Full Modular | OS: Windows 10
Keep the stock
if temps/noice don't get to your liking then upgrade
I ran the 1230v3 with the stock cooler, liked it a lot tbh
CPU: Xeon 1230v3 - GPU: GTX 770  - SSD: 120GB 840 Evo - HDD: WD Blue 1TB - RAM: Ballistix 8GB - Case: CM N400 - PSU: CX 600M - Cooling: Cooler Master 212 Evo
Update Plans: Mini ITX this bitch
It's up to you. If you want to spend money for aesthetics, go for it. Unlike performance, it's not really something we can decide if it's worth it or not for you.
That depends entirely on you.
I think the Intel stock coolers are fine when it comes to noise.
They just look like garbage. But I can not tell you if the looks of it bothers you or not. Only you can see that. So see what it looks like when it's assembled and then decide.
Personally I would get a different cooler just for aesthetics.
Follow your topics. 80 Watts is quite a loot to handle for a stock cooler. If you're not at full load it will be no problem but if you do some serious work ... :/ idk.
a 212 evo equivalent will be quieter and have your cpu run cooler.
http://linustechtips.com/main/topic/334934-unofficial-ltt-beginners-guide/ (by Minibois) and a few things that will make our community interaction more pleasent:
1. FOLLOW your own topics        2.Try to QUOTE people so we can read through things easier
3.Use
PCPARTPICKER.COM - easy and most importantly approved here        4.Mark your topics SOLVED if they are
Don't change a running system
I think I'm gonna upgrade for aesthetics. The ARCTIC cooler comes with a white fan which will look really nice with the black and white scheme of my build. Plus it'll be a little better than the stock cooler and a little quieter, which I'm not too worried about acoustics but it's a nice bonus. Only $15
No one can tell you if you should get something for aesthetics. Personally, i hate stock coolers because they never work on me for some reason, and they are loud. But if it's a cheap cooler and it makes you happy, sure, go for it
System
  • CPU
    I7-4790K @ 4,7GHz
  • Motherboard
    Asus MAXIMUS Formula VI
  • RAM
    Kingston HyperX FURY 16GB Kit (2x8GB) 1866MHz
  • GPU
    MSI GTX 1070 Gaming X
  • Case
    Cooler Master Cosmos SE
  • Storage
    Samsung 840 EVO 500GB+WD Green 3TB
  • PSU
    EVGA SuperNOVA 850G2 80PLUS Gold Certified
  • Display(s)
    ASUS PB277Q 27" WQHD 2560x1440 75Hz 1ms
  • Cooling
    Corsair H105 with AP121s and Phanteks fans
  • Keyboard
    Logitech G610 Orion
  • Mouse
    E-3lue E-Blue Mazer II 2500 DPI Blue LED 2.4GHz Wireless Optical Gaming Mouse
  • Sound
    Audio-Technica ATH-M20x
  • Operating System
    Windows 10
Well, it's not very different from a stock cooler, i'd say if you're buying aftermarket at least get something with heatpipes
http://www.newegg.com/Product/Product.aspx?Item=9SIA66Z28G2596&cm_re=raijintek-_-9SIA66Z28G2596-_-Product
http://www.newegg.com/Product/Product.aspx?Item=N82E16835186093
System
  • CPU
    I7-4790K @ 4,7GHz
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
  • Cooling
  • Keyboard
    Logitech G610 Orion
  • Mouse
  • Sound
  • Operating System
    Windows 10
Nah, I think I'll pass on the heatpipes. I don't need the extra cooling power of heat pipes, plus I kind of like the low profile look. It shows the black and white fan that goes with the rest of my build. If I wanted heatpipes I'd get a Cooler Master Hyper T2 and probably change out the fan for a white fan.
But overall, a tower style heat pipe cooler is a little overkill and the ARCTIC Alpine 11 Plus is all I need.
