Hello everyone, I have a problem with my PC, espacially the OS. I have 2 drives, SSD for OS and HDD Data. My HDD was my main drive not long ago before I installed my SSD. I did a fresh installed when I putted my SSD with both drive connected. My problem is when I unplugged my HDD or change Boot order for SSD, my windows won't boot. It seems that the system reserved partition is on the wrong drive(See picture below, yes it's in French, sorry). Any idea how to move it without an OS reinstall. Thx
post-68435-0-76737700-1442626429_thumb.j
https://linustechtips.com/topic/452356-system-reserved-partition-on-wrong-drive/
It does not ave the System reserved on the wrong drive. Windows will always create a Reserved partition on the physical hard disk it is installed to.
In this case, you have had Windows installed on both, so both drives have the System Reserved partition - that is not a problem.
Your second disk though, has the recovery partition - you can repartition disk 0 and copy the Recovery partition if you need that.
As for why it wont boot, whats the error when you try to boot off the new drive?
Desktop: Ryzen9 5950X | ASUS ROG Crosshair VIII Hero (Wifi) | EVGA RTX 3080Ti FTW3 | 32GB (2x16GB) Corsair Dominator Platinum RGB Pro 3600Mhz | EKWB EK-AIO 360D-RGB | EKWB EK-Vardar RGB Fans | 1TB Samsung 980 Pro, 4TB Samsung 980 Pro | Corsair 5000D Airflow | Corsair HX850 Platinum PSU | Asus ROG 42" OLED PG42UQ + LG 32" 32GK850G Monitor | Roccat Vulcan TKL Pro Keyboard | Logitech G Pro X Superlight  | MicroLab Solo 7C Speakers | Audio-Technica ATH-M50xBT2 LE Headphones | TC-Helicon GoXLR | Audio-Technica AT2035 | LTT Desk Mat | XBOX-X Controller | Windows 11 Pro
Server: Fractal Design Define R6 | Ryzen 3950x | ASRock X570 Taichi | Asus RTX 4060 Dual OC | 64GB (4x16GB) Corsair Vengeance LPX 3000Mhz | Corsair RM850v2 PSU | Fractal S36 Triple AIO + 4 Additional Venturi 120mm Fans | 8 x 20TB Seagate Exos X22 | 4 x 16TB Seagate Exos X18 | 3 x 2TB Samsung 970 Evo Plus NVMe | LSI 9211-8i HBA
NAS: Innovision 4U 24-bay chassis (12GB MiniHD SGIO Backplane) | Intel Core i9-10980xe | EVGA X299 FTW-K | EVGA RTX 2080Ti Super FTW3 | 128GB (8x16GB) Corsair Vengeance LPX 3200Mhz | DEEPCOOL PN1000M PSU| Noctua NH-D12L Chromax Black | 16 x 16TB Seagate Exos X18 | 2 x 2TB Samsung 990 Pro | 2 x 2TB Intel U.2 P4510 | LSI 9305-24i HBA
You should be able to fix it by opening an elevated Command Prompt, and running:
bcdboot C:\windows /s C:
If you can boot up into recovery and open a command prompt then you can also do:
bootrec /fixmbr
bootrec /fixboot
