Does plexiglass build a static charge?
Solved by ThomasD,
Hello people,
I was planning to mod my case and put a window on the side, for this I was going to use 3mm plexiglass (cut to size, polished with screw holes etc) but a friend told me plexiglass can build / store static. is this true? I don't want to use it if that's the case and what alternatives could I use?
Thank you.
Sorry, I totally missed the part about why you asked the title question.
So yes, a plexi window (or any other form of plastic window) could build up a charge. The thing is, that charge is not going anywhere and certainly would not cause a problem with your system.
Because if it did, then it would be a problem with pretty much every chassis that has a window.
Plexi window to your heart's content.
