Is there ANYWAY to recover data on a USB Drive? I accidently deleted some stuff...
@Captain_WD
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
https://linustechtips.com/topic/451757-well-crap-recovering-data-help/
grab a program like undelete360 or Recuva, and try them, don't do anything else with the drive at all until you try to recover the data. and don't try to recover the data back to the drive recover it to your computer's HDD or SSD and note that it may not work because of how USB drives work but there is always a chance it will.
Troubleshooting a pc will make you believe in gremlins.
--Thread killer--
I tried Recuva but all it said was "invalid drive size"
i've used undelete360 with decent success, i think you can use it as a trial now instead of a free version but it should work
--Thread killer--
I can't even open it. Like when you hit start > computer > and it shows the drivers, the PC says it is there but Application not found
hm idk what it could be, maybe some virus or corrupt drivers or install or something. kind of at a loss. :/ might just be gone
--Thread killer--
@Captain_WD
Hey there DarkBlade2117,
Apologies for the late response, I was off for a few days.
As the guys pointed out, you can use a third-party recovery tool (they listed some of them) and see if any of them is able to recover the data. Your best shot would be to contact a data recovery company but their services can be costly.
Do check it for malware and see if it's properly recognized in BIOS, Device Manager and Disk Management. You can try these things on other computers as well just to make sure the problem is within the the drive and not the computer itself (but make sure there isn't any unwanted malware on it!).
Captain_WD.
If this helped you, like and choose it as best answer - you might help someone else with the same issue. ^_^
WDC Representative, http://www.wdc.com/
