Low draw distance / LOD in all games
ShellShock
so basically in all the games i play there is a certain distance at which textures like shadows, grass, and rocks will load. the problem is that this distance is so short that it ruins my gaming experience. Basically as somebody has described it before, there's an invisible bubble around my character where all textures and detail show perfectly fine, but outside of that bubble they will not appear. i can be walking through a field of grass in GTA V and i will see the textures appear out of nowhere as i keep walking. as i move back a little bit, they will disappear as they get outside of this small bubble that i described.
here's a a link i found of a person who is having the same issue as me.
http://www.tomshardware.co.uk/answers/id-2135966/strange-lod-shadow-issue-games.html
I have an I7-4790k, gtx 970, 1tb hdd, 8gb ram,
if anybody could provide any info on this issue i would really appreciate it.
anisotropic filtering? or slow HDD loading of textures?
Aftermarket 980Ti >= Fury X >= Reference 980Ti > Fury > 980 > 390X > 390 >= 970 380X > 380 >= 960 > 950 >= 370 > 750Ti = 360
"The Orange Box" || CPU: i5 4690k || RAM: Kingston Hyper X Fury 16GB || Case: Aerocool DS200 (Orange) || Cooler: Cryorig R1 Ultimate || Storage: Kingston SSDNow V300 240GB + WD Black 1TB || PSU: Corsair RM750 || Mobo: ASUS Z97-A || GPU: EVGA GTX 970 FTW+
"Unnamed Form Factor Switch" || CPU: i7 6700K || RAM: Kingston HyperX Fury 16GB || Case: Phanteks Enthoo Evolv Mini ITX (White) || Cooler: Cryorig R1 Ultimate (Green Cover) || Storage: Samsung 850 Evo 1TB || PSU: XFX XTR 550W || Mobo: ASUS Z170I Pro Gaming || GPU: EVGA GTX 970 FTW+
Screenshots atleast...
System specs
  • Graphics card: Asus GTX 980 Ti (Temp target: 60c, fan speed: slow as hell)
  • CPU: Intel 6700k @ 4.2Ghz
  • CPU Heatsink: ThermalRight Silver Arrow Extreme
  • Motherboard: Asus Maximus Viii Gene
  • Ram: 8GB of DDR4 @ 3000Mhz
  • Headphone source: O2 + Odac
  • Mic input: Creative X-Fi Titanium HD
  • Case: Fractal Design Arc midi R2
  • Boot Drive: Samsung 840 Pro 128GB
  • Storage: Seagate SSHD 2TB
  • PSU: Be quiet! Dark Power Pro 550w
Peripherals
  • Monitor: Asus ROG Swift PG278Q
  • Mouse: Razer DeathAdder Chroma (16.5 inch/360)
  • Mouse surface: Mionix Sargas 900
  • Tablet: Wacom Intuos Pen
  • Keyboard: Filco Majestouch Ninja, MX Brown, Ten Keyless
  • Headphones: AKG K7xx
  • IEMs: BrainWavs S1
sorry, i'm not on my gaming desktop at the moment. i'll try and post some screenshots or make a video in a few hours when i can
Sure, just mention my name, or reply to me so I get a notification when you do.
System specs
Peripherals
Might be loading of the textures.
Either that or running low on vram. 4GB on the 970 should be enough tho
~~~SnapDragon~~~
| CPU: AMD Ryzen 7 3700X @ PBO & -0.06v offset | CPU Cooler: Scythe Ninja 5 |RAM: 32GB G.Skill Flare X 3200MHz @ 3600MHz 1.45V| Mobo: Gigabyte X570 Aorus Elite  | Storage: Crucial MX300 500GB + Western Digital Blue M.2 250GB + Seagate Barracuda 2TB + Western Digital 1TB Blue | Graphics Card: Asus ROG Strix RTX 2070 Super Advanced 8G | Case: Cooler Master HAF X | PSU: Superflower Leadex Silver 650W |
thats Level of Detail
present in every game out there since gpus are too weak to render such ridiculous amount of detail at far away (or even MID) distances
problem is, usually the distance is enough close so you see pop ins, either texture, model or shadow
make sure you max render distance out and maybe disable some of the taxing stuff
thats the price you have to pay to play a game made out of polygons and textures :D games are increasing detail all the time, so you have to keep buying new gpus
we will have to wait for Euclideon to fix this.
ok I managed to take a few quick screencaps, I can probably do a better job if I try to make a video later but I gotta head out the door pretty soon.
here's the link for the screencaps I took. you can see in each picture how the detail in the shadow increases as I get closer to it
http://imgur.com/a/HCaqN​
Link didn't work.
System specs
Peripherals
Link didn't work.
yea idk what the deal with that is. it works when you copy and paste it in the browser, though. if its still giving issues ill re upload them in a bit
Still no work
System specs
Peripherals
I understand what you're saying. my issue is just that there is a certain line where it starts to cut off these certain things like the detail of the shadow, in the screenshots I posted, and the distance is so close that its just so easily noticeable.
my gtx 970 can run most of the games I play well above 60fps at 1080p. but maybe the issue i'm having might be something else. maybe it's just not even a real issue at all like you're explaining. or, if buying a better gpu is all I need to do, then I could deal with that.
Just how the game is I would have though, probably look the same on anyone's PC.
System specs
Peripherals
Disable any DOF or motion blur.
Mid-range Emulation Gaming and Video Rendering PC
[CPU] i7 4790k 4.7GHz & 1.233v Delidded w/ CLU & vice method [Cooling] Corsair H100i [Mobo] Asus Z97-A [GPU] MSI GTX 1070 SeaHawk X[RAM] G.Skill TridentX 2400 9-11-11-30 CR1 [PSU] Corsair 750M
