Ok I am kinda knew here at the LTT forums but I could use some help on deciding what monitor to get. I have an AMD GPU an R9 290 to be exact. So here is my dilemma I have narrowed it down to two but I cant decide if the ASUS MG279Q 1440p 144hz IPS panel is better for me or the BENQ XL2730Z 1440p 144hz TN panel. I am a gamer and I would love the higher resolution and refresh rates that they both offer but I also have other hobbies like graphic design and video production that having an IPS panel could come in handy with. However after reading the reviews on newegg I have some doubts with the quality of the ASUS panel and I wanted to get some opinions from you guys. Should i just go with the BENQ TN panel or  should I try my luck with the ASUS IPS?
https://linustechtips.com/topic/451327-i-could-use-some-help/
Definitely get IPS if youre going to be doing video and photo work :)
Asus makes some of the better monitors out there, you shouldnt be worried ^_^
https://linustechtips.com/topic/451327-i-could-use-some-help/#findComment-6051393
IPS is much better then TN
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
https://linustechtips.com/topic/451327-i-could-use-some-help/#findComment-6051394
