USB 3.1 backwards compatible with 3.0?
If I buy a USB 3.1 memory stick, will it work at USB 3.0 speeds in a USB 3.0 port? Or will it not be compatible?
Does anybody know the difference between the two types of USB?
The only diffference is the speed, but they are compatible with each other.
It'll be the exact same thing if you plugged a USB 3 drive into a USB 2 port.
just with an added .1
Logic.
"I believe that if life gives you lemons, you should make lemonade... And try to find somebody whose life has given them vodka, and have a party."
-Ron White
USB 3.1 Gen 1 is USB 3.0 5gbps
USB 3.1 Gen 2 is USB 3.1 10gbps
As far as I know, you can show any usb into any usb and you'll be fine. But someone correct me if I'm wrong
CPU: some amd thing Motherboard: its black RAM: its memory thats for sure GPU: r7 260x Case: corsair spec 01 Storage: 1tb of it PSU: 430w, so many watts
Display: its asus Cooling: fans Keyboard: logitech g710+ #browns4lyfe Mouse: its a logitech Sound: its what you hear Operating System: winders
If it fits, it will work, and if it doesn't fit then you can use an adapter to make it fit and then it will work. That's how USB has always been, doesn't matter what revisions.
Hi there @
Yes, the USB 3.1 standard is backwards compatible with USB 3.0 and USB 2.0. However, if you connect a USB 3.1 device to a USB 3.0 port, then the speed will be limited to the speed of the port, so the maximum available speed will be 5.0 Gb/s.
Hope this helps and feel free to ask any questions you may have.
Cheers! :)
If this post helped you, please like and choose it as a best answer.   :)
http://www.wdc.com/en/
