My university claims it has gigabit ethernet hookups in all the dorms (best speedtest I've seen is about 400 down and 850 up so I believe them) but recently it's been shitting the bed with dropped connections. This is a ping to google to show how sparse the connection can be - almost to the point where it's unusable. Do they just have poor infrastructure that can't handle too many users all at the same time, or does it sound like I'm being throttled (may or may not have been torrenting a lot of textbooks) or does it sound like something else to you guys?
post-18088-0-21056700-1442365835_thumb.p
https://linustechtips.com/topic/450696-sooo-whats-going-on/
That connection is cancer.
My rig: Intel Core i7-8700K OC 4.8 | NZXT Kraken X62 | ASUS Z370-F | 16 GB Trident Z RGB 3000 (2x8) | EVGA 1070 SC | EVGA SuperNova NEX650G1 | NZXT H700 | Samsung 250GB 850-EVO | 2x 2TB Seagate Barracuda HDDs
https://linustechtips.com/topic/450696-sooo-whats-going-on/#findComment-6042913
damm dude wtf its like the whole dorm is downloading 4k porn at the same time
*thinks it's a good idea*
*starts doing it himself*
"yeet."
https://linustechtips.com/topic/450696-sooo-whats-going-on/#findComment-6042932
This is what I'm saying. Sometimes it's really snappy and reliable but it's gone downhill the last few days
If this is at night, then it's like 75% chances porno bc all the college guys who had gfs in high school but had to break up bc college are hungry.
https://linustechtips.com/topic/450696-sooo-whats-going-on/#findComment-6042950
In my dorm, I can't even ping Google. I don't know why but pinging any IP's doesn't work. I can do a speed test just fine, and the net is pretty quick, but for whatever reason pinging with cmd doesn't yield any results. On my desktop, laptop or the school computers in the labs, the result is the same.
https://linustechtips.com/topic/450696-sooo-whats-going-on/#findComment-6042955
maybe the switch cant handle many concurent users?
The speeds in my dorm will get as low at 5 mb/s down at times, but the connection seems to be pretty good (think they are using ruckus hardware)
Cpu: Ryzen 2700 @ 4.0Ghz | Motherboard: Hero VI x370 | Gpu: EVGA RTX 2080 | Cooler: Custom Water loop | Ram: 16GB Trident Z 3000MHz
PSU: RM650x + Braided cables | Case:  painted Corsair c70 | Monitor: MSI 1440p 144hz VA | Drives: 500GB 850 Evo (OS)
Laptop: 2014 Razer blade 14" Desktop: http://imgur.com/AQZh2sj , http://imgur.com/ukAXerd
https://linustechtips.com/topic/450696-sooo-whats-going-on/#findComment-6042957
run tunnel bear somewhere close to you and see if its ip throttle if not all thouse HS kiddes are out to play with their woodies
https://linustechtips.com/topic/450696-sooo-whats-going-on/#findComment-6043018
Get urself a range extender.  Or just tell everyone to fap some other time.  We don't have time for that plus I find that a clearer sound is much better than picture so maybe dolby surround porn with 1080p
I'm playing my Xbone on 3 LG Curved monitors-No one ever
Please, read CoC it helps, it helped me it should help you-Every competent member
Resident bad pun maker.....please excuse them
https://linustechtips.com/topic/450696-sooo-whats-going-on/#findComment-6043058
I tried running a vpn and it's the same story. I'm pretty sure it's just a network that can't handle all the residents and it's dropping packets everywhere as a result.
https://linustechtips.com/topic/450696-sooo-whats-going-on/#findComment-6043061
yea honestly go down your dorm nock on the doors really fast run back in and do a speed test garented 50% of them will x right out of that bitch
https://linustechtips.com/topic/450696-sooo-whats-going-on/#findComment-6043141
