I did a window mod on my Corsair 400r and when I tried to close the side, it was very hard to put on and screw the thumbscrews on. I know that this likely happened because the glass is in the way of something but I was wondering if anyone has suggestions on how to fix it. Thanks is advance!
EDIT: It also causes there to be an opening along the top of the panel.
My Stuff! :D
My Stuff
  • Main Build - Soon to change due to it being dead
  • 4790k @ 4.7Ghz
  • Corsair 750D
  • Swiftech H320
  • MSI Z97s SLI
  • 7950 Vapor-X
  • 16GB Corsair Vengance  Blue LP 1600Mhz
  • 120GB Samsung 840
  • 2TB Seagate Barracuda
  • Corsair HX750
  • ​Peripherals
  • Logitech G700s
  • Bitfenix, Corsair, and Darkside cable extensions
  • Das Professional with Cherry MX Brown's & Custom Keycaps
  • 3x ASUS VS238H-P w/ Triple monitor mount in PLP
  • AudioTechnica ATH-M50's
  • Blue Yeti Microphone
  • TurtleBeach PX3 Wireless
  • Logitech C920 Webcam
  • Precision Audio Bookshelf Speakers
  • AudioSource AMP-100
  • Logitech G27 Racing setup
  • Laptop - Acer 7750G-9855
  • i7 2630QM
  • AMD 6650M GPU
  • 120GB Samsung 840 EVO
  • 8GB RAM
  • Operating System: Windows 7 Home Premium
  • Blu-ray Drive
  • Netbook - HP Pavillion DM1
  • AMD E-450 APU
  • 4GB RAM
  • 500gb HDD
  • OS: Ubuntu 12.04
  • Cell Phone - OnePlus One
  • 5.5-inch 1080p Screen
  • Qualcomm Snapdragon 801 processor @2.5Ghz
  • 13 Megapixel rear camera
  • 5 megapixel wide angle front facing camera
  • 3100 mAh non-removal battery
  • AC wifi
  • Cell Phone #2 - Nexus 5
  • 5 Inch 1080p Screen
  • Snapdragon 800
  • 8 megapixel rear camera
  • 1.3 megapixel front camera
  • 2300 mAh non-removable battery
  • AC wifi
  • Upgrades for 2014
  • GTX 970
  • i7 4690k
  • 16gb RAM
  • 1x 1440 or 1600p Monitor
  • Das Mechanical Keyboard
https://linustechtips.com/topic/45051-window-mod-caused-side-panel-issues/
Pictures? Hard to suggest anything form just words.
Feel free to message me if you want to chat!
Yeah pictures are kind of needed..
Case: NZXT H440 | CPU: i5 4670K @ 4.5 GHz | GPU: MSI 970, Kraken G10 | Mobo: ASRock Z97 Extreme3 | Cooler: H100i | PSU: Corsair AX750 w/ Sleeved Cables | Display: 3xBenQ RL2455M | Fans: 5xNoctua NF-F12, 1xBitFenix Spectre |
Pictures on the way!
EDIT: Current;y waiting for the damn samsung media scanner >.>
My Stuff! :D
My Stuff
  • 4790k @ 4.7Ghz
  • Corsair 750D
  • Swiftech H320
  • MSI Z97s SLI
  • 7950 Vapor-X
  • 120GB Samsung 840
  • Corsair HX750
  • ​Peripherals
  • Logitech G700s
  • i7 2630QM
  • AMD 6650M GPU
  • 8GB RAM
  • Blu-ray Drive
  • AMD E-450 APU
  • 4GB RAM
  • 500gb HDD
  • OS: Ubuntu 12.04
  • AC wifi
  • Snapdragon 800
  • AC wifi
  • Upgrades for 2014
  • GTX 970
  • i7 4690k
  • 16gb RAM
Is it hitting your cooler?
EDIT: I see you have an H60, nvm
| i5-4670k @ 4.2Ghz | Corsair H100i | Gigabyte Z87X-UD4H | Corsair Vengeance Pro 8GB | ASUS Geforce GTX 770 |
| Samsung 840 Pro 128GB | WD Black 1TB | Corsair AX760 | Fractal Design Define R4 Black w/ Window | Corsair AF140 x2 |
| Windows 8.1 | ASUS 23" 1080p monitor | CM Storm Quickfire Stealth- MX Blue | Logitech G9x | Logitech G930 |
My Stuff! :D
My Stuff
  • 4790k @ 4.7Ghz
  • Corsair 750D
  • Swiftech H320
  • MSI Z97s SLI
  • 7950 Vapor-X
  • 120GB Samsung 840
  • Corsair HX750
  • ​Peripherals
  • Logitech G700s
  • i7 2630QM
  • AMD 6650M GPU
  • 8GB RAM
  • Blu-ray Drive
  • AMD E-450 APU
  • 4GB RAM
  • 500gb HDD
  • OS: Ubuntu 12.04
  • AC wifi
  • Snapdragon 800
  • AC wifi
  • Upgrades for 2014
  • GTX 970
  • i7 4690k
  • 16gb RAM
Yeah it looks like your plexi is hitting the lip on the chassis as it's to large mate, I'ld try shave some off the edges and see if you can't get it in then :D
Would sanding it down with a Demel work?
My Stuff! :D
My Stuff
  • 4790k @ 4.7Ghz
  • Corsair 750D
  • Swiftech H320
  • MSI Z97s SLI
  • 7950 Vapor-X
  • 120GB Samsung 840
  • Corsair HX750
  • ​Peripherals
  • Logitech G700s
  • i7 2630QM
  • AMD 6650M GPU
  • 8GB RAM
  • Blu-ray Drive
  • AMD E-450 APU
  • 4GB RAM
  • 500gb HDD
  • OS: Ubuntu 12.04
  • AC wifi
  • Snapdragon 800
  • AC wifi
  • Upgrades for 2014
  • GTX 970
  • i7 4690k
  • 16gb RAM
Yeah I would probly take a bit off with a dremel and then polish up the edges with a light sanding, Make sure to measure how far in that lip actually goes in from each edge of the chassis to make sure you take off enough too.
Measure twice, cut once :)
Alright thanks, will try to get time for it tomorrow!
My Stuff! :D
My Stuff
  • 4790k @ 4.7Ghz
  • Corsair 750D
  • Swiftech H320
  • MSI Z97s SLI
  • 7950 Vapor-X
  • 120GB Samsung 840
  • Corsair HX750
  • ​Peripherals
  • Logitech G700s
  • i7 2630QM
  • AMD 6650M GPU
  • 8GB RAM
  • Blu-ray Drive
  • AMD E-450 APU
  • 4GB RAM
  • 500gb HDD
  • OS: Ubuntu 12.04
  • AC wifi
  • Snapdragon 800
  • AC wifi
  • Upgrades for 2014
  • GTX 970
  • i7 4690k
  • 16gb RAM
I cut twice and never measure.. :P
