So I'm looking to buy a mouse for every day use and comfort but also for some CS:GO (Of course ^^). I've always used cheap 15 Euro mice and haven't had a problem with them but I want to try and see if a more expensive mouse really makes a difference or not.... I've watched some videos and read some forums on mice and decided to go for either Logitech or Steelseries so out of these two brands which mouse really performs the best for around the 60Euro mark?
(I don't want the 'Finalmouse' thingy xD)
https://linustechtips.com/topic/450170-looking-for-a-good-mouse-help/
I got and love the corsair m65, it may be heavy for you so I'd just take out the weights :)
Sergeant, United States Marine Corps
Network Administrator, Comptia A+, Security+, Cisco Certified Networking Associate
From a G3258 to dual Xeon E5-2670's
Corsair Gaming m65 RGB. Best gaming mouse
Everyday build:
CPU: Intel Core i7 5960x - GPU(s): 2x EVGA GTX 980 Ti Superclocked+ ACX2.0+ (SLI) - Cooler: be quiet! Dark Rock Pro 3 - Motherboard: ASUS Sabertooth X99 - RAM: 32GB Kingston HyperX Fury Black DDR4 4x8GB (2666MHz) - Storage: Intel 750 Series 1.2TB + 4TB WD Black - Case: Corsair 760T White - PSU: SeaSonic 1200W 80+ Platinum Certified - OS: Windows 10 Pro - Wireless Adapter: TP-Link Archer T9E - Monitor: Acer XB270HU bprz - Keyboard: Corsair K70 RGB - Mouse(s): Corsair Gaming M65 RGB + Logitech MX Master - Headphones: Sennheiser PC363D
http://pcpartpicker.com/p/WhyK99 https://linustechtips.com/main/topic/474247-r8-my-build/
Weekend build:
CPU: Intel Core i7 5930k - GPU(s): 2x EVGA GTX 980 Ti Classified ACX2.0+ (SLI) - Cooler: NZXT Kraken X61 - Motherboard: ASUS X99-Deluxe - RAM: 32GB Crucial Ballistix Sport LT DDR4 4x8GB (2666MHz) - Storage: Samsung 950 Pro 512GB m.2 & 2TB Samsung 850 Evo - Case: Phanteks Enthoo Evolv - PSU: SeaSonic SnowSilent 1050W 80+ Platinum Certified - OS: Windows 10 Home - Monitor: Dell S2716DG 144hz - Keyboard: Corsair STRAFE RGB - Mouse: Corsair Gaming M65 RGB - Headphones: Sennheiser PC363D
http://pcpartpicker.com/p/YYK93C
Logitech G502. Excellent build quality, adjustable weights, incredible software, all your settings are stored on the mouse and each button is fully programmable to whatever you like. Up to five DPI levels, all adjustable from snail to Voyager 1 speeds, with as many profiles as you like. All are switchable via a program shortcut bindable to the mouse. Then there's the support that Logitech is famous for.
Oh, and there's the hyper-scroll wheel. I can't get used to not having one anymore. It makes going on forums a delight.
How about the Steelseries sensei or kana?
I prefer the rival over the sensei, that's just me though.
it has built in acceleration...
Yeah, the only Corsair mouse to get is M45. Different weights and a good optical sensor. It'd be amazing it wasn't so small in the hand.
Look into the Mionix Castor mouse or do you want macros?
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
