Fury X Coil Whine
Solved by Glenwing,
Does any one know if the issues with the coil whine has been fixed? The pump noise isn't an issue as it will go in a custom loop so the pump will be gone anyway.
Thanks guys
Coil whine is on a unit-by-unit basis, it's not something that is "fixed" as if it were a problem on every card and now won't be present on any card in the future.
Featured Topics
CloseTheDoor ·
pchelp ·
Posted in CPUs, Motherboards, and Memory4 -
pontikos ·
Posted in Troubleshooting2 -
4
wolfgangam ·
Posted in Windows3 -
9
3
