H97 Motherboard Help
Go to solution Solved by Serpius,
I'm building a pc for only gaming. I need help on which motherboard I should get. I want to be able to use an overclockable cpu in the future and use larger gpu's like gtx 970's. What's the best deal I can get for a mobo for these needs (preferably red and H97)?
Get yourself an Intel Z97 chipset based motherboard. You can't go wrong with the upgrade possibilities and the features that go with those motherboards, which includes multiple PCI-e x16 bus slots.
Something like this will do the job and any Intel LGA 1150 processor will work.
Motherboard: MSI Z97 PC MATE ATX LGA1150 Motherboard  ($84.99 @ Amazon)
Total: $84.99
Generated by PCPartPicker 2015-09-11 19:55 EDT-0400
Total: $84.99
Buzzsaw - I'm Buzzsaw and you're not.
CPU -- Intel Core i7 7740X @ 4.30GHz Kaby Lake 14nm Technology * RAM -- 16.0 GB Dual-Channel Unknown @ 1466MHz (15-16-16-35)
Motherboard -- ASUSTeK COMPUTER INC. TUF X299 MARK 2 (LGA 2066 R4) *
Graphics -- SAMSUNG (1920x1080@59Hz) -- 4096 MB ATI Radeon RX 560 Series
Storage -- 223 GB SanDisk Ultra II 240GB (SSD) -- 256 GB Crucial_CT275MX300SSD1 (SSD) -- 931 GB Western Digital WDC WD10EZEX-00BN5A0 (SATA) -- 2794 GB BUFFALO External HDD USB Device
Optical Drives -- ASUS DRW-24B1ST * Audio -- Realtek High Definition Audio
https://linustechtips.com/topic/448197-h97-motherboard-help/#findComment-6010517
