Custom Keycaps for Razer Blackwidow Stealth 2015?
LLOYD-AF
Hey people,
As the title says I'm wondering if its possible to replace the keycaps and if so what site you would recommend. I'm based in the UK.
Thank you.
Azure Fists - "Grown men playing with each other since 2009"
CPU : Intel® Core™ i5-4590T, OS : Windows 10 64bit + Custom Alienware Console Interface, GPU : NVIDIA® GeForce® GTX 860M 2GB GDDR5, RAM : 8GB Dual Channel DDR3L 1600MHz, SSD : Kingston V300 240GB, WIFI : Intel® Dual Band Wireless-AC 7265 2x2 + Bluetooth 4.0, CASE : Alienware Alpha, PSU : External Power Brick, MOBO : Custom Dell Motherboard.
CPU : i5 6600, Mobo : Asus Z97i-Plus, RAM : 16GB DDR4 3000mhz Corsair Vengeance LED, GPU : Gigabyte G1 GTX 1080, Case : Silverstone RVZ02, Storage : SanDisk 1TB M.2, PSU : Silverstone Strider SST-SX700-LG, Display(s) : AOC Q2963PM 29" IPS Ultra Wide 21:9, Fans : Noctua NH-L9i with Be Quiet Pure Wings 2, Keyboard : Razer Blackwidow Stealth 2015, Mouse : Razer Naga 2015, Sound : LG Wireless Soundbar /Razer Kraken Pro, OS : Windows 10
Razer switches have a cherry stem, so any keycaps for cherry switches are good to go.
The Razer BlackWidow actually has a nonstandard layout so most keysets unfortunately will NOT work.  Compare the size of the keycaps in the bottom row of your nonstandard BlackWidow and a standard Novatouch.  Also, you'd have to find additional keycaps for the macros on the left hand side.
I'm only looking to change the WASD and Arrow keys at the moment not the full layout.
Oh then yup any keycaps that work for cherry boards will work for the BlackWidow.  I would suggest these or these (wasd allows for customization).  Make sure to get one for wasd and one for arrow keys and not 2 of a kind because they have different profiles.
