Hey guys, I am finally going to be buying a Gaming PC on Christmas. My build will compose of the following parts :
AMD FX-8350 ( CPU )
PowerColor Raedon R9 260x ( GPU )
16GB Ram 4x4 Sticks ; I dont know what speed to buy ( mRam )
750GB-1TB HardDrive ( Storage )
Motherboard - Still looking
EVGA Power Supply 500W ( PSU )
Cooler Master N200 ( Case )
Hey guys, I don't know what motherboard to purchase that supports AMD FX-8350 and my GPU... I need a really cheap one under 65$ or 75$ max...
If you guys can help me by sending my suggestions of good motherboards that supports overclocking my fx-8350 and x2 gpu slots
with on-board wifi ! please help!
( my case has ONE usb 3.0 port so if the motherboard could support that, i'd be happy as well )
https://linustechtips.com/topic/446990-i-need-help-with-building-a-pc/
This build needs reworking for a gaming PC, can you give us an overall budget?
Different PCPartPickers for different countries:
UK-----Italy----Canada-----Spain-----Germany-----Austrailia-----New Zealand-----'Murica-----France-----India
10 minutes ago, Stardar1 said:
Well, with an i7, GTX 1080, Full tower and flashy lights, it can obviously only be for one thing:
Solitaire.
What this guy said.  It needs more Intel and less RAM  :P
and not a 260x
Solitaire.
um i had built this on pcpartpicker for 500$ lol even with a motherboard but i took it out, so i am willing to spend up to 550 at MAX
Give me 3 minutes
also, do you need a monitor/keyboard/mouse/headphones/speakers/wifi adapter?
Solitaire.
Give me 3 minutes
um no i have A cheap keyboard and mouse that is okay, and the wifi adapter i dont NEED IF the motherboard has on-board wifi, and thanks!
Better build
CPU: Intel Core i3-4130 3.4GHz Dual-Core Processor  ($103.99 @ SuperBiiz)
Motherboard: Gigabyte GA-B85-HD3 ATX LGA1150 Motherboard  ($66.98 @ OutletPC)
Video Card: Sapphire Radeon R9 280 3GB DUAL-X Video Card  ($177.98 @ Newegg)
Case: Corsair 200R ATX Mid Tower Case  ($49.99 @ Micro Center)
Total: $555.81
Generated by PCPartPicker 2015-09-09 13:56 EDT-0400
        Setup
CPU: i3 4160|Motherboard: MSI Z97 PC MATE|RAM: Kingston HyperX Blue 8GB(2x4GB)|GPU: Sapphire Nitro R9 380 4GB|PSU: Seasonic M12II EVO 620W Modular|Storage: 1TB WD Blue|Case: NZXT S340 Black|PCIe devices: TP-Link WDN4800| Montior: ASUS VE247H| Others: PS3/PS4
Better build
Total: $555.81
Hey thanks for the help but um... I kind of wanted a amd processor because they have more cores 6-8 and it is cheaper overall. And yeah.. how is a i3 better than a fx-6300 or a fx-8350? just asking i am a noob.
http://pcpartpicker.com/p/7MsdVn
at this low of a budget, i do like the fx-6300 because of its price/performance
Solitaire.
the i3 has way better single core performance, but a 6300 may be preferable at this budget because it has 6 threads and a decent gaming performance
Solitaire.
http://pcpartpicker.com/p/mLmf4D
i think this is a pretty good build
Main PC |CPU - i7-6700k|GPU - R9 290x tri-x 4gb|RAM - 16gb ddr4|MOBO - MSI z170 - A PRO|HDD - WD 1TB/240gb Sandisk |PSU - 700w Raidmax
Laptop |CPU - i7 4720hq|GPU - 960m 2gb|Ram - 8gb 2x4|Model - y50-70 Touch|SSD - 240gb Patriot drive|Display - 1920x1080 IPS touch
The architecture of the FX CPUs are over 4 years old. Why would you want that? Also they aren't cheaper overall bedtime you factor in a decent motherboard and cooler for the chips because they need some good stuff to overclock? Class starts by.
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
hey dude thanks for the budget build, it is kinda off but i mean i cna manage, but the thing is i wanted the cooler master n200 case, is it possible i can sub out the case you found and chose for the n200?
A i3 is better because although it has less cores it's stronger per core which is more useful in gaming. AMD CPUs have more cores but the core strength is weak making it not a good choice for gaming. No point in having 6/8 cores if they're weak and most games won't use those cores.
http://linustechtips.com/main/topic/401217-more-updated-fx-vs-intel-for-gaming/
        Setup
CoolerMaster n200 is a micro-atx case, which will limit build size and require a smaller motherboard
Solitaire.
Guys I know everyone might say INTEL is stronger/better than AMD but i personally like AMD because it is cheaper , yeah i know you get what you pay for but i mean if i where to get an INTEL cpu it would be at the MINIMUM of an i5 cpu, I hate i3's because they are slow and petty. Yeah i know they better than fx-6300/8350 but i need atleast an i5... My dads laptop had a i5 with 8gb ram and it was slow as hell. Yes i know laptops and desktops have majorly different parts but i mean if thats what i will be getting, I want an amd fx-6300 or i5 ATLEAST.
go with the the build i suggested. i really recommend finding an extra 100 and getting an i5 4440 but otherwise its good
Since the post of this thread, I've gotten litterally 20+ responses, and all of you have different opinions. most of the replies suggest amd processors just because its cheaper and has more cores. Yes i know intel is stronger per core but i'd rather have 4-6 cores over 2 cores. I'm pretty sure 6 cores overrun a 2 core processor even if it is intel.
What i plan on doing is combining all of your guys suggestions/builds and finding the cheapest AMD build for my self. Yes i know i'm going to get alot of hate for being on an amd side but i mean my family is poor. my budget was at 250$ at first. Yes I know there are alot of richer people and will complain but my family is risking this money for me because i'm getting good grades. My family is on the poorer side. We need all the money we could get, and for someone to say dish out 100$ extra its nothing, is quite ignorant... some people don't know wether people are on the poorer or richer side, unforuntately i'm on the poorer side. i simply asked for a PC build under 550 $... Yet i been getting more than that. Thanks. But I wish to stick to AMD because I get more cores for a cheaper price. I had a i5 / 8gb ram laptop BRAND new and after two months it was slow as shit... Thats why I dont want to go with an intel processor when its $100 extra.
I kind of agree with this statement. you could go with the Pentium G2358 and set yourself up for an upgrade path, but it may be better to get the 6300 now and when you upgrade, which you will, getting a new motherboard to move up to an I5 or I7
Solitaire.
if you are going wit the fx-6300, this is the build you want:
slap on a 212 EVO for $30 and you can OC like a boss
or go for a smaller motherboard and get the micro atx case you wanted, but go with NVidia at this budget range.
Solitaire.
First of don't compare based on laptop experiences, one laptop CPUs are made to be less powerful and lower clock speed for a low heat so the power of a laptop i3 is not the same as a normal i3.Two you're thinking of speed wrong, the speed you feel of a computer has nothing to do with the CPU, the general speed that you feel of a computer is based on the OS and the storage. So i3s aren't 'slow' as clock speed doesn't affect the speed that you feel and i3s aren't even slow clock speeds anyway. Look at the link I posted AMD is not cheaper. A i3 is better than a FX 6300 easily.
        Setup
alright man sorry. i only suggested it. no way to know your situation :/
I had built a pc list on pcpartpicker for 518$ with an 8core amd processor 16GB RAM 4x4 sticks and a powercolor raedon 49 260x... with everything mobo storage etc... but thanks for the help. ill be deciding what i want later today.
on a single core performance: yes, easily
but games are going multi-threaded, and i know for a fact that this CPU can run GTA V at max settings, and other games at medium-high settings with good fps. now an i5 versus a fx 83x0, i5 all the way, but in this scenario, with a build that is not focused on single threaded performance, the 6300 is the better choice
Solitaire.
