I just bought DiRT 3 Complete edition on Steam and I'm running it on an HP Envy 17 but the game will not launch!  It'll say preparing to launch DiRT 3 and then it does NOTHING.  If there is anyone who can help me please do thank you!
I'm playing my Xbone on 3 LG Curved monitors-No one ever
Please, read CoC it helps, it helped me it should help you-Every competent member
Resident bad pun maker.....please excuse them
https://linustechtips.com/topic/446980-dirt-3-wont-launchshit/
Valve support?
Primary: Lenovo T61 / Intel Core2Duo T7200 @ 2.2GHz / 3GB DDR2 / NVIDIA Quadro NVS 140M / Fedora 22 <<<< THE WHITE KNIGHT
Secondary: Compaq Presario CQ56 / AMD V130 @ 2.3GHz / 2GB DDR3 / AMD Radeon HD 4250 / Windows 8.1 <<< THE FORGOTTEN HERO
https://linustechtips.com/topic/446980-dirt-3-wont-launchshit/#findComment-5991535
Valve support?
I guess I could do that but I haven't had good times with Valve Support....
https://linustechtips.com/topic/446980-dirt-3-wont-launchshit/#findComment-5991553
Valve support?
I figured a pro over here could help me out with this.
https://linustechtips.com/topic/446980-dirt-3-wont-launchshit/#findComment-5991560
Update GPU drivers. This sometimes help. And try running straight from the install folder. See if you get some error message (like missing dll or something).
Asrock 890GX Extreme 3 - AMD Phenom II X4 955 @3.50GHz - Arctic Cooling Freezer XTREME Rev.2 - 4GB Kingston HyperX - AMD Radeon HD7850 - Kingston V300 240GB - Samsung Spinpoint F3 1TB - Chieftec APS-750 - Cooler Master HAF912 PLUS
osu! profile
https://linustechtips.com/topic/446980-dirt-3-wont-launchshit/#findComment-5991641
I'm trying to locate that file, where would I find it?
https://linustechtips.com/topic/446980-dirt-3-wont-launchshit/#findComment-5991677
System Specs
CPU: Ryzen 5 5600x | Mobo: Gigabyte B550i Aorus Pro AX | RAM: Hyper X Fury 3600 64gb | GPU: Nvidia FE 4090 | Storage: WD Blk SN750 NVMe - 1tb, Samsung 860 Evo - 1tb, WD Blk - 6tb/5tb, WD Red - 10tb | PSU:Corsair ax860 | Cooling: AMD Wraith Stealth  Displays: 55" Samsung 4k Q80R, 24" BenQ XL2420TE/XL2411Z & Asus VG248QE | Kb: K70 RGB Blue | Mouse: Logitech G903 | Case: Fractal Torrent RGB | Extra: HTC Vive, Fanatec CSR/Shifters/CSR Elite Pedals w/ Rennsport stand, Thustmaster Warthog HOTAS, Track IR5,, ARCTIC Z3 Pro Triple Monitor Arm | OS: Win 10 Pro 64 bit
https://linustechtips.com/topic/446980-dirt-3-wont-launchshit/#findComment-5991701
Valve support?
Thanks guys I solved the problem actually thanks to your combined help xD  First I use Gala for steam support then Mo5 tells me about the install file and Nexxus showed me the forum.  When I tried to open via the install file it said OpenAL was missing so that's the issue!   Thanks guys!
https://linustechtips.com/topic/446980-dirt-3-wont-launchshit/#findComment-5991789
No problem mine was doing the same thing.
System Specs
https://linustechtips.com/topic/446980-dirt-3-wont-launchshit/#findComment-5993025
