Does anyone know where to buy a good mineral oil case???
I think Puget Systems has a kit.
i5-4690k@4.5GHz || MSI GTX 970 || MSI z97 Gaming 5 || NZXT Kraken x61 || WD Black 1TB || Crucial MX100 || 8GB Corsair Vengeance Pro || Corsair RM750 || NZXT H440 || Corsair k70 RGB mx browns || Acer H236HL || ViewSonic VX2255wm-4
https://linustechtips.com/topic/446606-mineral-oil-cooling/#findComment-5986306
They stopped producing them due to patent lawsuits.
I never did get mine, I still cry myself to sleep at night :(
@nicklmg
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/446606-mineral-oil-cooling/#findComment-5986312
Welcome to the Forums!
Unfortunately there are no more companies making mineral oil cases due to patent trolls, the previous builder Pudget used to have kits. The only way now is to get a motherboard tray or holder and a tank yourself to build an oil cooled system.
https://linustechtips.com/topic/446606-mineral-oil-cooling/#findComment-5986323
Fishtank will work, just have to build your own mounts
Star Citizen referral codes, to help support your fellow comrades!
UOLTT Discord server, come on over and chat!
i7 4790k/ Bequiet Pure Rock/Asrock h97 PRO4/ 8 GB Crucial TT/ Corsair RM 750/ H-440 Custom/  PNY GT 610
Damn you're like a modular human being. -ThatCoolBlueKidd
https://linustechtips.com/topic/446606-mineral-oil-cooling/#findComment-5986333
You could get a fish tank and mod it with a motherboard tray from frozencpu.  All you need is some acryllic over that to mount hard drives, etc...
https://linustechtips.com/topic/446606-mineral-oil-cooling/#findComment-5986336
where do i get the tray holders? do you know
you make them yourself...
thats part of building a PC in a fish tank
modding and construction
https://linustechtips.com/topic/446606-mineral-oil-cooling/#findComment-5986351
Frozencpu.com
https://linustechtips.com/topic/446606-mineral-oil-cooling/#findComment-5986401
Isn't frozen CPU dead and running on a skeleton crew?
It doesn't have to be from frozencpu.  I found some on Amazon too.
https://linustechtips.com/topic/446606-mineral-oil-cooling/#findComment-5986441
how big do y think a fish tank has to be for ATX
Here is the dimensions for different sizes of mobos but also don't forget to account for a location to put the PSU either at the bottom of the tank or on a mounting plate.
http://www.tomshardware.com/reviews/motherboard-selection-guide,3900-3.html
https://linustechtips.com/topic/446606-mineral-oil-cooling/#findComment-5987454
