Help Finding Case Please
Solved by OAcesync,
Order of expense
Corsair 200R http://uk.pcpartpicker.com/part/corsair-case-200r
Phanteks Enthoo Pro http://uk.pcpartpicker.com/part/phanteks-case-phes515pbk
NZXT S340 http://uk.pcpartpicker.com/part/nzxt-case-cas340wb1
Fractal Design Define S http://uk.pcpartpicker.com/part/fractal-design-case-fdcadefsbk
Fractal Design Arc Midi R2 http://uk.pcpartpicker.com/part/fractal-design-case-fdcaarcr2bl
Best one is Define S imo but I would recommend at least getting the Phanteks Enthoo Pro for non stressful and clean cable management
