i tried to post test a watercooled card dry for less than 10 seconds a pop .
no screen but not the first time .... i had a r7 250 that wouldnt post on this machine
its a dell xps 8300 is the mobo and bios incompatible with newer cards
i know omggg you tried to post a card without the cooling
it can cool to a certain extent by its self i just need help figuring out the problem
https://linustechtips.com/topic/444895-post-test/
This is true. It will last about 30 seconds before killing itself. If it did not post then there is another issue. Be careful since the PC won't automatically shut down if the card gets too hot. Update the bios if possible? Try a different slot? Might just be out of luck.
blackshades on
https://linustechtips.com/topic/444895-post-test/#findComment-5962441
power cables?
https://linustechtips.com/topic/444895-post-test/#findComment-5962461
oonly one 16x  and the card didnt do anything i might try and see if i can take it to a pc shop and have it fully tested
power cables?
all plugged in 700w psu
https://linustechtips.com/topic/444895-post-test/#findComment-5962491
Make sure you have your monitor inputs correct and such.
blackshades on
https://linustechtips.com/topic/444895-post-test/#findComment-5962499
