Fans spinning to fast when not under-load and I can't control fan speed
Solved by CaptainPebbleDash,
Make sure you followed all the correct instructions and put the CPU header into the CPU fan on the MB etc. Then download Corsair Link and you can manually adjust the RPMs through various modes like fixed, %, quiet, performance etc. You can also change the LED colour here.
Are your case fan's also going fast or is it just the AIO?
Featured Topics
Yousef65 ·
Posted in Troubleshooting0 -
AtomAlchemist ·
Posted in Servers, NAS, and Home Lab3 -
2
eric_s ·
Posted in Power Supplies11 -
1
Silencix ·
Posted in Cases and Mods5
