Posted September 1, 2015 Hi, My CPU is OC to 4.2 using the Hyper Cooler 212 Plus, the temperatures when my pc starts its between 18c, when gaming its somewhere 25c-35c, but when I´m in my room just watching videos or doing casual things with my pc, my room tends to get hot, and when I´m playing wou, sometimes I sweat. Is this normal? Or should I lower the O.C? The stock OC I believe it´s 3.5hz, also I have 3 fans on my pc case, 1 intake in the front and 2 exhaust, one in the back and one above. My CPU its the AMD FX-8320 Link to comment https://linustechtips.com/topic/442209-cpu-temps/ Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 1, 2015 Solution Perspiring is normal, yes. Case: Corsair 4000D Airflow; Motherboard: MSI ZZ490 Gaming Edge; CPU: i7 10700K @ 5.1GHz; Cooler: Noctua NHD15S Chromax; RAM: Corsair LPX DDR4 32GB 3200MHz; Graphics Card: Asus RTX 3080 TUF; Power: EVGA SuperNova 750G2; Storage: 2 x Seagate Barracuda 1TB; Crucial M500 240GB & MX100 512GB; Keyboard: Logitech G710+; Mouse: Logitech G502; Headphones / Amp: HiFiMan Sundara / Mayflower Objective 2; Monitor: Asus VG27AQ Link to comment https://linustechtips.com/topic/442209-cpu-temps/#findComment-5926968 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 1, 2015 What CPU? Spoiler Prometheus (Main Rig) CPU-Z Verification Laptop: Spoiler Intel Core i3-5005U, 8GB RAM, Crucial MX 100 128GB, Touch-Screen, Intel 7260 WiFi/Bluetooth card. Phone: Spoiler TruPureX, Asus Zenwatch 3. Game Consoles: Spoiler Softmodded Fat PS2 w/ 80GB HDD, and a Dreamcast. If you want my attention quote my post, or tag me. If you don't use PCPartPicker I will ignore your build. Link to comment https://linustechtips.com/topic/442209-cpu-temps/#findComment-5926969 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 1, 2015 Those temps are perfectly fine. Link to comment https://linustechtips.com/topic/442209-cpu-temps/#findComment-5926976 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 1, 2015 What CPU? Look like i5 5690k? but he dosent say. 35 degrees is great temp. Magical Pineapples
