G-Unit
Go to solution Solved by Atmos,
It's all done in mm like any forward thinking country or people.
But we hur dawn in thesm states, use the methad that our forefathers dun used.
Just ignore inches/feet all together and use mm.
I'm not modding a case... Yet. I'm going to do a mock up of a case for custom painting. Are all PC cases made with mm measurements or inches? I'm guessing it's millimeters, but Google (and their new logo) reveals nothing on the subject. Maybe I'm not using the right search terms?
Intel Core i7-6700K | Corsair H105 | Asus Z170I PRO GAMING | G.Skill TridentZ Series 16GB | 950 PRO 512GB M.2
Asus GeForce GTX 980 Ti 6GB STRIX OC | BitFenix Prodigy (Black/Red) | XFX PRO Black Edition 850W
My BuildPCPartPicker | CoC
https://linustechtips.com/topic/442186-g-unit/
Updated 2021 Desktop || 3700x || Asus x570 Tuf Gaming || 32gb Predator 3200mhz || 2080s XC Ultra || MSI 1440p144hz || DT990 + HD660 || GoXLR + ifi Zen Can || Avermedia Livestreamer 513 ||
New Home Dedicated Game Server || Xeon E5 2630Lv3 || 16gb 2333mhz ddr4 ECC || 2tb Sata SSD || 8tb Nas HDD || Radeon 6450 1g display adapter ||
https://linustechtips.com/topic/442186-g-unit/#findComment-5926513
mm
https://linustechtips.com/topic/442186-g-unit/#findComment-5926517
mm
Thanks, guys. I just wanted to make sure.
https://linustechtips.com/topic/442186-g-unit/#findComment-5926531
It's done in mm. Inches is a horrible measurement, especially when you start getting into fractions of an inch.
m8 my case is 9 inches and 1/17th, just joking lel.
Gpu: MSI 4G GTX 970 | Cpu: i5 4690k @4.6Ghz 1.23v | Cpu Cooler: Cryorig r1 ultimate | Ram: 1600mhz 2x8Gb corsair vengeance | Storage: sandisk ultra ii 128gb (os) 1TB WD Green | Psu: evga supernova g1 650watt | Case: fractal define s windowed |
https://linustechtips.com/topic/442186-g-unit/#findComment-5926543
Yes, it is terrible. And I hate that I rely on it so much, because in my mind I can understand how long say, a 13" graphics card is. But if you tell me that graphics card is 239mm long, I just blank out and stare into the distance, unable to render anything in my head even resembling a length measurement.
https://linustechtips.com/topic/442186-g-unit/#findComment-5926548
I can understand inches, when done in round inches, but not in 3/8th inches... What the hell is that?
I find it much easier to picture things in mm. Even if it's just a matter of rounding it to cm so it's an easier unit to picture.
https://linustechtips.com/topic/442186-g-unit/#findComment-5926575
I know how you feel... I can't grasp the concept of Celsius. How much is 10C? Oh, gee whiz, I don't know! I can do the math to figure it out, but I can't equate 10 with a feeling of temperature.
https://linustechtips.com/topic/442186-g-unit/#findComment-5926578
10C is like a really warm fridge or chilled display cases for cakes, but as for your case almost all of it is in metric there are some imperial things such as threading where the majority of threads are 6-32 for things and some M3 for other components like SSD or 2.5" drives.
https://linustechtips.com/topic/442186-g-unit/#findComment-5926650
