First Build Compatibility, Pricing, and Information. Help needed!
Precipitar
Go to solution Solved by Precipitar,
Final Build, We did it guys!!!! Thank you all so much for the help, it is greatly appreciated, like seriously =D.
Please feel free to comment and keep the suggestions coming, all new information and advice is always welcome.
Final Build:
CPU: Intel Core i5 4690K, http://www.pccasegear.com/index.php?main_page=product_info&products_id=27941
Motherboard: ASUS Z97-K, http://www.scorptec.com.au/product/Motherboards/Intel_Socket_1150/54772-Z97-K
GPU: MSI GTX 970 4GB, http://www.pccasegear.com/index.php?main_page=product_info&products_id=29086
Memory: Kingston HyperX Fury Blue 2x4GB DDR3 1866MHz, http://www.pccasegear.com/index.php?main_page=product_info&products_id=27402
SSD: Samsung 850 EVO 250GB, http://www.pccasegear.com/index.php?main_page=product_info&products_id=30448
HDD: WD Blue 1TB Sata 3 7200RPM, http://www.pccasegear.com/index.php?main_page=product_info&products_id=21231
Optical Drive: Pioneer BDR-209DBKS 16x Blu-Ray, http://www.pccasegear.com/index.php?main_page=product_info&products_id=31876
PSU: SeaSonic S12G 80+ Gold 650W, http://www.pccasegear.com/index.php?main_page=product_info&products_id=30963
Case: Nanoxia Deep Silence 1, http://www.pccasegear.com/index.php?main_page=product_info&products_id=31404
PC Part Picker Full List (Link May Not Work): http://au.pcpartpicker.com/p/Qg2BnQ
Thankyou very much, so far this is what i have on pc part lister (link still may not work):
http://au.pcpartpicker.com/p/rj9ngs
Intel i5 4690k
Asus z97 A
G.SKILL Ripjaws X Series 8GB
Crucial BX100 250GB 2.5"
WD 1TB 3.5"
GTX 970 MSI
Seasonic 550W 80+ Gold (550 all i need, even for an i7 upgrade? Do i only need more wats for SLI?)
Build seems solid!  That will do very well in most/all games.
Thnx, its because of all your help so thnx again =D
R9 390 seems to need a hell of a ton of PSU Wattage. If the 970 Doesn't need as much i will definitely be buying the 970, but if the power supply is the same or it doesn't cost much to upgrade to a PSU that can support the 390 in the long term, 390 it is.
i would go with the 390
BigDay
Final Build:
the asus z97-k doesn't support sli. keep this in mind if you get the 970. you won't be able to add another card in the future. the psu wattage is overkill. you only need 500w for an overclock on the cpu and gpu
BigDay
Also what part of the case does it attach to? is it screwed on then plugged into a motherboard slot, sorry never built a computer before and especially stupid when it comes to motherboards
Look up one of linus' build guides. He goes over pretty much everything in them.
SLI isn't even going to be considered for quite some time =P. And by the time it is considered i wouldn't mind buying a whole new motherboard, maybe even a whole new build.
Ok, Thankyou very much
yes, 600w min
Thanks for info, might stick with 970, with 650w psu so i can upgrade to either a 980 ti with i7 or something better whenever game requirements start exceeding 970.
Sorry for starting this thread again, there's a new deal at pc case gear that'll save me $60ish.
Wondering if this bundle deal is better than what i previously stated as my final build.
The bundle comes with RAM, Motherboard, and Processor, http://www.pccasegear.com/index.php?main_page=product_info&cPath=187_1490&products_id=31328&zenid=55a71cb19ba14640d8eaad79c27b6596
RAM: Kingston HyperX Fury Red 2x4 DDR3
Processor: Intel Xeon E3 1231 V3
Motherboard: MSI H97 Gaming 3
Are these parts better than my previously mentioned build that i said was my final? the RAM, Motherboard and  Processor are:
RAM:Kingston HyperX Fury Blue 2x4 DDR3
Processor: Intel i5 4690K
Thanks for all the help.
Also ofc wondering if the above mentioned bundle is compatible with my build if they replace the current parts of what i said in the earlier post.
Xeon's are not made for gaming. Stick with the I5
1. If you stick with the GTX 970, you dont need that much extra watts on the PSU.
2. If you stick with the PSU, go with the R9 390 as it beats that 970 in perf in most situations.
3. If you have USB 3.0 and 2.0 up front, you are able to use them both because there are different headers on the motherboard for each standard.
Everything else seems legit. :D
"The REVISED Companion Cube, v2.1" - "1440p, lock on." Discover it by clicking here.   // Peripherals - Corsair Strafe RGB  + Steelseries Rival
CPU - i7-6700k // Motherboard - ASRock Z170 Extreme 6+ // CPU Cooler - Corsair H100i GTX // Memory - 16GB HyperX Fury DDR4-2133 (2x8GB) // Storage - Samsung 850 EVO 120GB + Seagate Barracuda 1TB // Graphics - Crossfire Sapphire R9 Fury Tri-X // PSU -  EVGA SuperNova G2 850W // Case - Corsair Carbide Air 540 (Steel) // Devices - iPhone 6 Plus, Macbook Pro //
Awesome thankyou, PSU is there for upgrades maybe to a 980 ti or even better. thanks anyway =)
With the r9 390 im sort of a Geforce Gtx nut right now, so yeah.... =P
Thanks for the info glad to know.
Also do you mind reading what i just recently posted above, wanted to know about a bundle deal goin on atm and want to know if the parts r better/compatible as they r cheaper.
Thanks again =D
Thanks again =D
I would stick with the i5 4690k since CPUs would last you a couple of GPU upgrades before the start to hamper GPU performance, and especially with DX12 arriving, CPUs could last much longer. Also, since im a OC enthusiast, an OC 4690k is miles faster than the Xeon E3.
Thankyou very much, sticking with current build it is. In the end another $60 is not that much to get, and not very hard to work another week max.
Thanks again, i guess sticking with my finalised build in the previous post will suffice.
Looks like a great build.  I'm glad to see that the build ignored "futureproofing", and instead just tried to get great performance NOW.  By the way, post a picture of the finished build when you're done,
  • 2 weeks later...
Damn been a while since i visited here, sorry bout no reply have been having some financial issues so don't have much "free" money lying around atm. Build will have to be bought next month or maybe even month after. I'll still post a nice pic of it once its done, but there will be a delay =P
