I am looking for a pretty cheap gaming PC build to play mainly Skyrim. Hopefully I can get at least 60fps on Medium or higher. I would be very greatful if anyone were to help me out on this, or even some suggestions to help pick out parts. I can buy used from Kijiji in the Toronto area, and any other Website that ships to or is in Ontario. My budget is about $450 CAD, and that includes any taxes or fees that I might come across.
Thanks for your help! :3
Budget: about $450 CAD (Tax included)
Location: Toronto, Ontario (I can purchase from Kijiji in this area or stores that ship or are located here)
CPU: Intel i5 4590 @ 3.7GHz | Motherboard: H81-M-P33 | RAM: 16GB DDR3 GPU: Nvidia GTX 970 HDD: WD Blue JVPX 1TB | Keyboard: Corsair K70 Red Mouse: G502
https://linustechtips.com/topic/440943-skyrim-pc-build/
Probably not gonna happen.
i5-4690k@4.5GHz || MSI GTX 970 || MSI z97 Gaming 5 || NZXT Kraken x61 || WD Black 1TB || Crucial MX100 || 8GB Corsair Vengeance Pro || Corsair RM750 || NZXT H440 || Corsair k70 RGB mx browns || Acer H236HL || ViewSonic VX2255wm-4
https://linustechtips.com/topic/440943-skyrim-pc-build/#findComment-5910032
This is literally the best I could do, its over budget but if you go for anything less than this, youre rlly not gonna have a good time :/
CPU: Intel Core i3-4170 3.7GHz Dual-Core Processor  ($144.74 @ DirectCanada)
Motherboard: ASRock H97 Anniversary ATX LGA1150 Motherboard  ($104.75 @ Vuugo)
Memory: A-Data XPG V1.0 8GB (2 x 4GB) DDR3-1600 Memory  ($54.98 @ NCIX)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($59.99 @ NCIX)
Video Card: Gigabyte GeForce GTX 750 Ti 2GB WINDFORCE Video Card  ($164.00 @ Vuugo)
Case: Corsair 200R ATX Mid Tower Case  ($58.99 @ NCIX)
Power Supply: SeaSonic 450W 80+ Gold Certified Semi-Modular ATX Power Supply  ($85.24 @ DirectCanada)
Total: $672.69
Generated by PCPartPicker 2015-08-30 19:16 EDT-0400
https://linustechtips.com/topic/440943-skyrim-pc-build/#findComment-5910055
You could make a fairly good build with that budget but it will probably be entirely of used parts, I strongly recommend watching the first Scrapyard Wars series and look on places like Craig's list for parts.
Edit: If you also need peripherals such as keyboard, monitor, etc. it can't be done.
My Build:
CPU: i7 4770k GPU: GTX 780 Direct CUII Motherboard: Asus Maximus VI Hero SSD: 840 EVO 250GB HDD: 2xSeagate 2 TB PSU: EVGA Supernova G2 650W
https://linustechtips.com/topic/440943-skyrim-pc-build/#findComment-5910058
CPU: AMD A10-7850K 3.7GHz Quad-Core Processor  ($162.98 @ NCIX)
Motherboard: Gigabyte GA-F2A68HM-DS2H Micro ATX FM2+ Motherboard  ($62.98 @ Newegg Canada)
Power Supply: EVGA 500W 80+ Bronze Certified ATX Power Supply  ($54.99 @ NCIX)
Total: $449.91
Generated by PCPartPicker 2015-08-30 19:17 EDT-0400
https://linustechtips.com/topic/440943-skyrim-pc-build/#findComment-5910066
I built my daughter her first Gaming PC for about 3 bills, Only used part was the 500 gig SATA HD
A10-7870k and a gigabyte 88 chipset MB. A case with a 380watt PSU that was half price cause of a scratch for like 40ish....it was a few months ago.
It must be ok cause she gave me 60 bucks for Skyrim the elder scrolls.
I am playing Crysis 3 on my 7850k with the cheap 68 chipset mb with no probs
One nice thing about the A10 is that I can use any old PSU over 200 watts with a 4 pin atx connector and any old case.
Theres a guy on youtube DIYsomething that just screwed the MB on to a piece of plywood and used bungie cords or something for the rest of the stuff.
Fast Ram is a good idea....2133 being the sweetspot, my MSI 68 board wont handle 2133 but dau's 88 board will take 2400
https://linustechtips.com/topic/440943-skyrim-pc-build/#findComment-5910114
Buy all the parts brand new except for the graphics card, then find a nice used graphics card.
You'll save like $80 by doing that.
And it's easy to get a PC running Skyrim, my Core 2 Duo rig (specs in signature) can run Skyrim just fine and it's only cost me $50 in upgrades.
(EDIT: I play Skyrim at 1440x900 resolution, fullscreen with High detail. No mods. Very nice, smooth FPS.)
https://linustechtips.com/topic/440943-skyrim-pc-build/#findComment-5910133
Thanks for the replies, that was like really quick. The responses were good and I think I am going to buy a lot a used arts and I was planning to from the start. I know of a couple used graphics cards in my area, like a gtx 770 for 175, and a 580 for 75. Anyway thanks again for the replies and hopefully I can find enough parts to build a decent rig for my budget or a little more even.
Also if anyone can give me advice on upgrading perhaps my Laptop to use a desktop graphics card using a pci-e riser, psu and separate screen/monitor, instead of a new pc, because currently my Laptop can play Skyrim Somewhat Modded (official high res pack, and pure waters) at like average 15 fps on low-med settings but if I were to add a desktop card I think I might be able to get higher than that. Thoughts?
https://linustechtips.com/topic/440943-skyrim-pc-build/#findComment-5910217
Getting a external gpu to work with a laptop is a drag and the costs sum up.
For a new build under 450  this would do skyrim in 1080p ultra with 4x msaa around 60 fps
http://ca.pcpartpicker.com/p/rw7s4D  You should just overclock that cpu to 4.0 at least, should work with a stock cooler.
If you have a hdd lying around you can save some money of course.
Something like a 580 for 80 would not be bad of course, but youd have to get at least a 500w bronze evga psu for
https://linustechtips.com/topic/440943-skyrim-pc-build/#findComment-5910295
your better off with a xbone or a ps4 and a copy of skyrim
Xbox one and Ps4 dont play skyrim
https://linustechtips.com/topic/440943-skyrim-pc-build/#findComment-5911276
My honest thoughts on this is that you should save more money. Once you get into the $750 range it's difficult, but possible. Otherwise, just buy a Console.
Guide to GTX 900 Series: http://linustechtips.com/main/topic/457526-nvidia-900-series-basic-performance-guide/
Performance expert, building noob.
There is no such thing as excess in hardware.
https://linustechtips.com/topic/440943-skyrim-pc-build/#findComment-5912238
CPU i7 6700k MB  MSI Z170A Pro Carbon GPU Zotac GTX980Ti amp!extreme RAM 16GB DDR4 Corsair Vengeance 3k CASE Corsair 760T PSU Corsair RM750i MOUSE Logitech G9x KB Logitech G910 HS Sennheiser GSP 500 SC Asus Xonar 7.1 MONITOR Acer Predator xb270hu Storage 1x1TB + 2x500GB Samsung 7200U/m - 2x500GB SSD Samsung 850EVO
https://linustechtips.com/topic/440943-skyrim-pc-build/#findComment-5914944
I already have an Xbox one it just doesnt play skyrim and my Laptop only has integrated graphics and is an i3 so my performance isnt too bad but I would like to get a more gaming oriented PC
https://linustechtips.com/topic/440943-skyrim-pc-build/#findComment-5937333
Total: $449.91
That won't play Skyrim well.
http://www.bit-tech.net/hardware/cpus/2014/01/30/amd-a10-7850k-and-a10-7700k-kaveri-review/9
https://linustechtips.com/topic/440943-skyrim-pc-build/#findComment-5937449
