Switching audio device requires program restart
Every time I plug in my derp headphones, I have to restart anything playing audio for it to go to the headphones (or vice versa) Why is this a thing? It is very obnoxious. Asrock Sound Blaster, windows 10.
Im going to sit in on this as I've been wanting to figure this out too
LTT Community Standards                                               Welcome!-A quick guide for new members to LTT
Man's Machine- i7-7700k@5.0GHz / Asus M8H / GTX 1080Ti / 4x4gb Gskill 3000 CL15  / Custom loop / 240gb Intel SSD / 3tb HDD / Corsair RM1000x / Dell S2716DG
The Lady's Rig- G3258@4.4GHz(1.39v) on Hyper 212 / Gigabyte GA-B85M / gtx750 / 8gb PNY xlr8 / 500gb seagate HDD / CS 450M / Asus PB277Q
Depends on program or game. When I want to switch from headphones to speakers or the other way around it works on the fly in bf3 but not in GTA V it is dependent on the game and not any "issue". I guess it might have to do with how the audio of the engine works or something. Not sure though.
http://linustechtips.com/main/topic/334934-unofficial-ltt-beginners-guide/ (by Minibois) and a few things that will make our community interaction more pleasent:
1. FOLLOW your own topics        2.Try to QUOTE people so we can read through things easier
3.Use
PCPARTPICKER.COM - easy and most importantly approved here        4.Mark your topics SOLVED if they are
Don't change a running system
It happens on my brothers PC which has a cheapie 40$ motherboard with realtek audio, and mine, which uses the game blaster. I could see why it would happen though. If a game uses 7.1 audio and you switch to headphones, all of the sudden your sound config changes. But with such a "high end" soundcard, you would think that it could re process the 7.1 audio as stereo for the headphones. Put that quad core audio processor to work! I think I will probably just buy an 3.5mm splitter and just plug the speakers and headphones into it, turning off the speakers when I want to use headphones. Obviously this won't work with anything other then stereo speakers though.
Or any surround sound setup that utilizes a receiver...
Hey! New SIgnature!
I'm supposedly a person on the Internet, but you'll never know if I'm human or not ;)
