how much watts do i need?
Go to solution Solved by WoodenMarker,
thanks for the answer i got the 8320 really cheap and it was still in the box not open i read on some forums after i got my cpu that its not a problem to run 2 280x but i guess 1 will do just fine just 1 last thing will an FSP Raider 650w do for this a single 280x and overclocked 8320?
It's a bit overkill. A decent 550w is already more than enough.
850W.
Get EVGA SuperNova G2/GS series PSU.
Intel Core i3 2100 @ 3.10GHz - Intel Stock Cooler - Zotac Geforce GT 610 2GB Synergy Edition
Intel DH61WW - Corsair® Value Select 4GBx1 DDR3 1600 MHz - Antec BP-300P PSU
WD Green 1TB - Seagate 2.5" HDD 1TB - Seagate Barracuda 500GB - Antec X1 E.
https://linustechtips.com/topic/439289-how-much-watts-do-i-need/#findComment-5889612
I'd recommend maybe a 850W Supply :D. I think 750w would do but i'd recommend 850w for a bit of security/headroom too.
Get a G2 Supernova, i have one and it does the job beautifully.
Hey bro i like yo *vomits on you*
SpOOkY  - Intel Core i7 4820K - Sapphire Radeon HD 7970GHZ Toxic Edition 6GB - 16GB Corsair Vengeance 1600Mhz - Gigabyte X79-UD3 - EVGA Supernova G2 850W
My GrApHiCs DeSiGn TeAcHeR Is GoInG To bE sO MaD
https://linustechtips.com/topic/439289-how-much-watts-do-i-need/#findComment-5889614
for 8300 CPU + 2x 280X I'd say 800-850W. if it were an intel CPU, then 700W would be enough but yeah.
https://linustechtips.com/topic/439289-how-much-watts-do-i-need/#findComment-5889622
hi i have an fx 8320 and i want to overclock it but im going to get an r9 280x and was thinking of getting another one in the future and cf them so i want to know how much watts does my psu need to have so that i can overclock my procesor and run the 2 r9 280x in cf
Aside from mentioning bottlenecks you should go for 750 to 850W
https://linustechtips.com/topic/439289-how-much-watts-do-i-need/#findComment-5889848
https://linustechtips.com/topic/439289-how-much-watts-do-i-need/#findComment-5890725
its too bad there isnt a sticky for this kind of information..
oh wait..
How do Reavers clean their spears?
|Specs in profile|
The Wheel of Time turns, and Ages come and pass, leaving memories that become legend. Legend fades to myth, and even myth is long forgotten when the Age that gave it birth comes again.
https://linustechtips.com/topic/439289-how-much-watts-do-i-need/#findComment-5892424
https://linustechtips.com/topic/439289-how-much-watts-do-i-need/#findComment-5900484
