Why would you use IE?
Try Chrome or Firefox!
Intel Core i3 2100 @ 3.10GHz - Intel Stock Cooler - Zotac Geforce GT 610 2GB Synergy Edition
Intel DH61WW - Corsair® Value Select 4GBx1 DDR3 1600 MHz - Antec BP-300P PSU
WD Green 1TB - Seagate 2.5" HDD 1TB - Seagate Barracuda 500GB - Antec X1 E.
Try this
Open the Reset Internet Explorer Settings dialog box. To do this, use one of the following methods:
Automatically open the Reset Internet Explorer Settings dialog box
Note This automatic wizard applies to Windows 7, Windows Vista, and Windows XP. If you are running Windows 8.1 or Windows 8, go to the "Manually open the Reset Internet Explorer Settings dialog box" method.
Click here to download the automatic wizard.
In the File Download dialog box, click Run, and then follow the steps in the wizard.
Close all Internet Explorer and Explorer windows that are currently open.
Start Internet Explorer.
Note If you are running Windows 8.1 or Windows 8, start Internet Explorer from the desktop. Changing your settings will affect both Internet Explorer and Internet Explorer that you start from the desktop.
On the Tools menu, tap or click Internet options. If you don't see the Tools menu, press Alt.
In the Internet Options window, tap or click the Advanced tab.
Tap or click Reset. If you're using Windows Internet Explorer 6, click Restore Default.
In the Reset Internet Explorer Settings dialog box, tap or click Reset.
Note Select the Delete personal settings check box if you also want to remove browsing history, search providers, Accelerators, home pages, Tracking Protection, and ActiveX Filtering data.
When Internet Explorer finishes applying the default settings, tap or click Close, and then tap or click OK.
Exit and then start Internet Explorer.
Notes
If you close all visible windows, but still get an error message when trying to reset, you might have processes running that are not visible. Restart Windows, start Internet Explorer, and try resetting again.
If you cannot start Internet Explorer, you can open the settings window by pressing Windows Key + R, typing inetcpl.cpl in the Run box, and then pressing Enter. After the window is open, follow the steps that are described in the "How to reset Internet Explorer settings" section.
https://support.microsoft.com/en-us/kb/923737
edit nvm didn't notice you tried this, lol tired.
Skype now supports Web UI
web.skype.com
Go to that.
It'll work with extension in chrome.
The reason i want to fix this is because i want to use it in my desktop.
It has the same feature as the desktop.
Try it.
Otherwise idk.
reinstall pc
Honestly, this is probably what you're going  to have to do.  Otherwise uninstall and reinstall internet explorer.
Please spend as much time writing your question, as you want me to spend responding to it.  Take some time, and explain your issue, please!
If you need to learn how to install Windows, check here:  http://linustechtips.com/main/topic/324871-guide-how-to-install-windows-the-right-way/
Event Viewer 101: https://youtu.be/GiF9N3fJbnE
or skype
If Internet Explorer is having issues then other core components of Windows are going to have issues.  Uninstall and reinstall IE, if that doesn't fix the problem try to find a Microsoft Fix It for the problem,.  And if that still doesn't fix the issues you're having you'll spend less time by just doing a clean install of the OS.
